Originally posted by Trub So if I use Program, Tv, Sv, Av, TAv modes and change to "Depth" the camera is going to apply some magic and give it better depth? What if I use the manual mode, will the camera ignore this setting? Sorry, I don't understand your answer completely so that is why I'm asking all the questions.
As Gary said. It applies to "P" mode and times when you push the "green" button.
You can have the camera prioritize it's programming for faster shutter speeds, smaller apertures, or the lens' optimal aperture (MTF). (Stated in your original quote)
So while the camera is still automatic, it will bias itself for different types of photography.
For example:
- If your goal was a freeze action or use in low light, you would set the P mode to prefer "Hi Speed".
- If you are doing landscape in P mode and want as much in focus as possible, use "Depth of Field".
- For situations with plenty of light where a specific subject is important, use "MTF".
It won't do anything magical. The camera just chooses a shutter speed and aperture combination to give you the type of picture results you're desiring. Does that make more sense?
