03-11-2012, 08:34 AM   #226
Ex Finn.'s Avatar
QuoteOriginally posted by oneeyedhawk Quote
With my guide scope, 60mm
I missed the "guide-scope" part.
03-11-2012, 06:10 PM   #227
Ex Finn.'s Avatar
I tried the venus shot with my 120mm f 7.5 refractor, pretty dissapointing, maybe I would have better luck with a 300 mm telephoto.
M 42 turned out little better, the K5 high ISO rocks. I wonder how well the astro-tracker would work with a 900mm FL telescope.
03-11-2012, 06:51 PM   #228
krp
krp's Avatar
QuoteOriginally posted by Ex Finn. Quote
Your Venus shot looks better than mine. I have concluded that the moon (and maybe the sun) is the only object I can image through my telescope without a tracking mount. This was taken last night at prime focus through a 90mm f11 refractor with my K-x:
03-11-2012, 07:43 PM   #229
Another trick to sharpness is to stop your lenses down one stop. Most lenses tend to be a little sharper when stopped down. On an unrelated note, here is a stack of 47 45s shots of M51 I took last night. This is a fun, but at times frustrating hobby!
03-12-2012, 02:10 AM   #230
Stone G.'s Avatar
I don't think that your Venus shot should be dissapointing considering that
1) you only have had 900mm FL to do with. For Venus you would normally need eypiece projection to get an effective FL of at least 2,000mm and up to 10,000mm when it is furthets away
2) Venus is always essentially a featureless disk due to the heavy clouds that always cover Venus' surface
3) Venus is always fairly low in the sky, where atmospheric seeing is worst. Thus, stacking is more or less a must to get clean pictures
It looks to me a that you have got a very fine telescope, as the image of the core of M42 also shows.
03-12-2012, 02:59 AM   #231
Ex Finn.'s Avatar
This would be much more fun with a computerized EQ. mount. I`ve done the EP projection bit, not very easy with my AZ-EL mount.
My 2.4 second shot of M42 resulted in nice color and brightness with some considerable star trails. I think I stick to moon-shots.
03-12-2012, 03:02 AM   #232
Ex Finn.'s Avatar
QuoteOriginally posted by krp Quote
Nice moonshot.
03-12-2012, 10:39 AM   #233
Ex Finn; Your venus shot is quite good Because venus is so bright it is easy to over expose. As you can see it is in its half moon phase the crescent phase is actually the brightest phase.Cut down the exposure time and then stack about 10 frames and see the difference. Your Orion shot shows the Trapezium stars A,B, C,D. This shows your scope is doing its job and your focus is good. Orion Nebula is very tricky to photo. Expose to long and you have to much nebulosity and no Trapezium. There are 10 trapezium stars but only two more you can expect to grab E,F. (both about 10th mag). There are other named features in the Orion neb. Like the fishes mouth,that can be missed on long hi resolution photos. Many photos of Orion you see in books are taken with several different parameters and overlayed in Photoshop to show all the features in one shot. The Trapezium has always been a test for the optical equipment you use. Frustrating and fun.
Hank
03-12-2012, 11:00 AM   #234
Here is one i took that includes the running man nebula but the trapezium is washed out. Used a stellarvue 102mm ed scope
Hank
03-12-2012, 02:23 PM   #235
Ex Finn.'s Avatar
Thank you for the tips and advice everyone.
Here is a 2.5 sec. shot. ISO 10 000. Does not take much to get trails.
03-12-2012, 03:12 PM   #236
again another this taken with the astrotracer 30 sec and at 300mm with the da 55-300mm zoom, single shot
03-12-2012, 03:41 PM   #237
Ex Finn.'s Avatar
That is pretty impressive, nice shot.
p.s. looked up trapezium, learn something new every day.
03-13-2012, 12:30 AM   #238
Nice, now take about 10 more and stack them. it will be stunning.
03-13-2012, 08:04 AM - 1 Like   #239
GWARmachine's Avatar
Orion!
Pentax K-5, Sigma(apo hsm2)70-200mm@200mm, f/3.5 ISO 800, 83 second single exposure. Tracked with AstroTrac.
03-13-2012, 05:06 PM   #240
Ex Finn.'s Avatar
Yes sir, nice shot. I tried stacking, not for me. So, anyone try astro-trac with a actual telescope?.
astronomy, astrophotgraphy, astrophotograhy, bill, camera, dslr, dss, exposures, f/1.8, images, lens, light, lights, lp, moon, night, night sky, photography, pk tether, post, settings, sigma, skies, stars, starscape, street, thanks
astrophotography with K-7 - issues =(. Please help? Nass Photographic Technique 40 02-10-2010 10:28 PM
Astrophotography with K10 J-Rod Photographic Technique 5 12-12-2009 06:08 PM
Astrophotography mithrandir Photographic Technique 1 11-26-2009 06:56 PM
K7 And Astrophotography Christopher M.W.T Pentax DSLR Discussion 49 11-25-2009 08:51 AM
Astrophotography elLuiggi Post Your Photos! 0 11-01-2007 05:43 PM
All times are GMT -7. The time now is 05:57 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
