Originally posted by walky Light is not what they recommend.
Well, light is all relative
Quote: The heavier the better because a heavy mount dampens any movement which is critical for long exposures -- which are usually needed for milky way, etc..
Right, I understand weight will improve the stability of the image.
However, strictly in terms of required support, I am surprised not to see any tracking mount with say, a 10 lbs max payload. The lower the payload, the lighter the mount would need to be, and thus the lesser it should cost.
When I look at Orion telescopes for example, the SkyView Pro costs $850 , or $400 without the compute/ motor drive/goto. That's got a 20 lbs payload. If the tripod was lighter, and the motor not as strong, I would expect to have a complete goto mount with 10 lbs in the $400 range. The electronics don't seem to be very expensive, given that a Celestron 60LCM can sell for $130 retail and include them.
It seems like this all stuff could be a bit more modular than it is. For instance, the electronics are only sold together with a motor drive, mount, or complete telescope, but never separate.
Quote: Forget light. They will start recommending a CG5 mount and that is heavy and expensive. Then you need tracking (motors to track on RA and DEC) so you don't get trails and then you have to learn to align with Polaris and find your stuff in the sky (or get GoTo capability). All this means $$$$ on gear surrounding the camera.
Yes, I know I want tracking & Goto before I will even try photographing stars. I'm just surprised at the price of even the entry-level mounts. CG-5 is slightly cheaper than Skyview Pro , but also heavier. And it looks like SV Pro may include a couple extra items that are optional with the CG-5
