Originally posted by djseeram Nice picture smigol. How do you cool your K10D? And why ISO 100?
Thanks! I've been through a few exercises with cooling my camera.
I originally had it modified by Spencers to remove the IR filter, making it sensitive to full-spectrum.
For about a year, I was cooling the outside of the camera with a peltier (TEC) device that was a power hog.
Earlier this year, I finally opened up the camera and added a cold finger to the frame inside the body. Because of the floating CCD for the shake reduction system, I could not put the cold finger directly on the sensor surface.
Instead, the cold finger touches the metal chassis and some of the components inside the frame. It does help to reduce noise and it stabilizes the temperature of the CCD as reported by EXIF.
Here are a few posts I made on my personal blog about the recent work on the camera.
The choice of ISO 100 goes back to some work I've done with measuring the readout noise of the system and maximizing dynamic range. Because the K10D is a CCD based system, the readout noise is not as adversely effected by ISO setting. For a year, I used 10 minute subs at 400 ISO. What I've found is that using 20 minute subs at ISO 100 gives cleaner results and a smoother noise texture than previous work at ISO 400. There are areas of amp glow that are unavoidable for the K10D. Because these areas have a non-linear noise profile, it can be difficult to remove them. Using ISO 100 also seems to help with controlling this amp glow as it will tend to saturate the data.
