Show Printable Version 294 Likes Search this Thread
03-06-2014, 11:24 PM   #751
smigol's Avatar
QuoteOriginally posted by Ex Finn. Quote
+1.
I am lucky to get 12 second exposures before LP gets out of hand. I can`t even start to comprehend 1200 sec.
The idea is to try to get signal above the noise floor of the camera and at the same time, not get the skyglow more than 1/3 of the full well capacity of the sensor.
I've done the math for my home site and my regular dark site and I've split the best values as much as I can. See point #4 on this post regarding noise floor and sky glow.
TL;DR: I'm compromising the proper duration I should be using at home (maybe 400-600 seconds) and proper duration I should be using at the dark site (maybe 1800 to 2400 seconds) for convenience of having just one library of files for calibration.
03-07-2014, 06:36 AM   #752
MJSfoto1956's Avatar
shot last night from 30 miles south of Boston, looking northeast towards Ursa Major (The Big Dipper). While there was obvious city "glow", the K-3 sensor is pretty good and the image cleans up well. Using the Astrotracer together with the 60-250mm at 250mm f/4 I was just able to make out two messier objects:
the full-res version is here: All sizes | Pentax K-3 + DA* 60-250mm + Astrotracer @ 250mm @ f/4 @ 40 seconds @ ISO 1000 | Flickr - Photo Sharing!
03-07-2014, 07:05 AM   #753
Iksobarg's Avatar
two hours from now I get to open the iOptron...
Someone is getting ready to ROCK & ROLL...
My odometer hit 44 today but I'm about as giddy as a little gushy eight-year-old girl.
03-07-2014, 09:41 AM   #754
smigol's Avatar
QuoteOriginally posted by Iksobarg Quote
What's the filter on the IDAS? With a non-full spectrum cam, you should be able to use just the IDAS filter.
Remember to focus on objects 1/3 from the center to give best focus across the field.
03-07-2014, 01:54 PM   #755
Iksobarg's Avatar
QuoteOriginally posted by smigol Quote
Thanks Stephen. I thought I was being overprotective with the UV filter over the IDAS. Taking the UV off then.
03-07-2014, 02:15 PM   #756
quick question: so if I have a series of celestial shots taken with Astrotracer w/ 250mm @ f4 and all the center stars are pin points, as are the upper left, lower left and upper right, however, with the lower right quadrant showing slight "donuts" I would assume this lens is slightly de-centered -- any agreement with that analysis?
Michael
03-07-2014, 11:24 PM   #757
smigol's Avatar
QuoteOriginally posted by MJSfoto1956 Quote
Michael
The doughnuts point to some element out of best position. What you describe does seem like it's not centered well.
Do you have an example that you can share? I'll run it through CCDI and see what it shows regarding centering and tilt.
A perfect target for testing that setup now is M44 or the Beehive. Good wide field, lots of stars across the area, well placed in the sky. Could be done with a lot of short exposures since it's all stars and no nebulosity.
03-12-2014, 06:35 AM   #758
VisualDarkness's Avatar
I went on a trip to the north with a bunch of other students and we got really lucky with the weather and activity one evening. K-5 + DA 14/2.8
03-12-2014, 08:41 AM   #759
smigol's Avatar
QuoteOriginally posted by VisualDarkness Quote
Very nice, I've not seen the Aurora in person. Have you tried video or timelapse?
03-12-2014, 12:14 PM   #760
Parry's Avatar
I recently bought an as new, mint Meyer Optik Gorlitz Orestegor 300/4.
Is this any good for taking pictures of the moon?
03-12-2014, 04:41 PM   #761
Yeah, a pretty bad timelapse but I messed up and have to redo and upload a new version.
03-12-2014, 07:49 PM   #762
QuoteOriginally posted by Parry Quote
It should work well. There's a thread on it from several years ago... It does appear to be a bit on the heavy side ~5lbs.
03-12-2014, 10:07 PM   #763
smigol's Avatar
I found some examples of the lens on flickr. The FOV of a 300 mm lens on APSC is 187 x 279 arcminutes. The size of the moon disc is 29.3 – 34.1 arcseconds. You'd still need to do a fair amount of cropping to feature just the moon when using this lens.
Important to note that the large number of aperture blades should reduce the star effect on high contrast edges. That alone would be useful to retain good separation of light and dark features near the terminator.
Since you already have the lens and the moon is up, why not shoot some and see what you get? Remember that the surface of the moon is lit by sunlight, so the sunny 16 rule is your guide for proper exposure.
04-01-2014, 03:47 AM   #764
Tsuken's Avatar
I've just come in from my backyard, where I shot this, my first catch of the Orion Nebula:
Messier 42 - The Orion Nebula by -Occasionally Focused-
I'm absolutely over the moon. (This is processed from a jpg, until I load the RAW onto my computer; the iPad does many photographic things well, but tricky RAW files ain't one.)
04-01-2014, 04:16 AM   #765
Iksobarg's Avatar
Lovely Orion!
Really fine work!!
I'm a little jealous...
gonna catchup someday
astronomy, astrophotgraphy, astrophotograhy, bill, camera, dslr, dss, exposures, f/1.8, images, lens, light, lights, lp, moon, night, night sky, photography, pk tether, post, settings, sigma, skies, stars, starscape, street, thanks
astrophotography with K-7 - issues =(. Please help? Nass Photographic Technique 40 02-10-2010 10:28 PM
Astrophotography with K10 J-Rod Photographic Technique 5 12-12-2009 06:08 PM
Astrophotography mithrandir Photographic Technique 1 11-26-2009 06:56 PM
K7 And Astrophotography Christopher M.W.T Pentax DSLR Discussion 49 11-25-2009 08:51 AM
Astrophotography elLuiggi Post Your Photos! 0 11-01-2007 05:43 PM
All times are GMT -7. The time now is 06:37 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
