@Kendigitize : This looks simply great ! I really want to learn how to do something like this ! But first of all I think I need to improve my Astronomic knowledge a little bit
Really nice to see that with just a normal camera you can get so close and take a picture of a planet so far away... ( I guess you used a very good magnifying lens or a telescope?)
@bavd : Of course I can
1.) First of all I set the focus on manual and set it on "endless"
2.) I activated the RAW-Mode which is really important
3.) I put the camera on the treestomp as I said
4.) I tried to get it even with the integrated electronic water level
5.) I turned off the Image Stabilisation of the Camera
6.) I set the exposure time manually on 30seconds (which is a bit too much, if you zoom in on the picture you can clearly see short startrails, so the stars arent really "sharp")
7.) I chose an iso-value that I thought is suitable
8.) I did a single exposure of the Milky way...
Thats how the image was created. One single exposure. No stacking at all, It's one single frame. I guess because it was so cold I was able to use higher ISO than normal, but with that I'm not sure.
In Photoshop I used the "tonal correction" or "levels" and dragged the slider from the right (where the light colors are) to the left. If you do that you can clearly see what you change and just take what you think looks best. Then I went to the "color correction" because in the dark the white balance often isnt right and set it to a value that looked good ... Thats all. But really, there are much better ways to do this. You should read some other articles from people that know what they're doing
