10-07-2015, 10:05 AM - 1 Like   #1081
Kendigitize's Avatar
Super Blood Moon Eclipse
My Pix of the Bloodmoon - K-30 and SMC FA50
https://www.flickr.com/photos/millermagic/21817610046/in/dateposted-public/
https://www.flickr.com/photos/millermagic/21655858488/in/dateposted-public/
https://www.flickr.com/photos/millermagic/21843748345/in/dateposted-public/
10-07-2015, 12:46 PM   #1082
pixelsaurus's Avatar
Very cool.
10-07-2015, 02:07 PM   #1083
QuoteOriginally posted by Kendigitize Quote
Nicely done, I'm curious what your delay was between photos?
10-08-2015, 09:55 AM   #1084
QuoteOriginally posted by rkappleby Quote
I set the camera to 2 min between shots and the counter set for 999 shots. That gives me more then enough shots of the eclipse phases, plus it's easy to stop the interval shooting, adjust the ISO a bit as the moon darkens, and get the interval mode back on. This composite is about every 4th frame stacked in Startrails. The Moon moves it's own distance about every 5 min, so you could set the interval to 4-5 min and get about the same results as the photo.
10-08-2015, 11:46 AM   #1085
Hey great information I appreciate it and will make a note for the future
10-09-2015, 07:44 PM   #1086
Damn! How did you maintain focus as the moon was moving?
10-10-2015, 03:39 PM   #1087
QuoteOriginally posted by Newtophotos Quote
A tripod and the focus for the moon or stars with my FA50 1.4 is infinity, so it's always in focus once you set it.
10-15-2015, 06:57 AM   #1088
A tripod and the focus for the moon or stars is infinity, so it's always in focus once you set it.
That's interesting. I had manually focused my DA 55-300mm on the moon at infinity and the photos were blurry. Bringing it in slightly from infinity fixed the focus.
10-15-2015, 07:40 AM   #1089
Infinity is different on all lenses. sometimes it at the very end of the focus travel, sometimes a bit backed off. Some lens have an infinity mark and it might be a bit off also. And with a lens like the 18-135wr that have no stop, infinity can be hard to find in the dark. I used the FA50mm 1.4 and infinity is all the way to the end, on my copy. With a 300mm lens infinity for the Moon would be out of focus.
10-15-2015, 10:02 AM   #1090
Emperor and Senpai
VoiceOfReason's Avatar
I pre-focus for infinity and the stick tape on it to keep it there.
11-02-2015, 08:43 PM   #1091
Emperor and Senpai
Okay, how do I keep the stars from being blobs? https://i.imgur.com/uSpOYta.jpg
11-02-2015, 09:20 PM   #1092
Aaron28's Avatar
QuoteOriginally posted by VoiceOfReason Quote
being blobs
that looks pretty typical and it seems you have caught Andromeda as well (nice!) you could stop down........
11-03-2015, 04:33 AM   #1093
Ex Finn.'s Avatar
Focus on a bright star in live view at 10X magnification. That does look pretty good however.
12-17-2015, 08:53 AM   #1094
I'm new here, as well as relatively new to astrophotography with my Pentax. I must say that I am finding a great many helpful and creative ideas regarding astrophotography and equipment posted here. That said, perhaps I can get some advice regarding a question that has been troubling me. I'm shooting with an older Pentax *ist DL @ ISO800 employing a range of Pentax telephoto lens. These are carried on a small driven mount at a celestial rate. My problem is the long delay between the taking of my 60-120 second exposures and the camera processing the image (normally taking slightly longer than the exposure itself) and the camera resetting itself before I can start the next exposure in a series.
I've checked the camera's manual a number of times, but don't see anything directly addressing the situation, nor ways around it. I assume this is because most typical exposures are expected to be factions of a second, not minutes. So, is there any camera setting or way to obtain a series of extended exposures that circumvents/delays the camera's handling of new images until the series of shots (5-10 in number) are completed?
12-17-2015, 10:21 AM   #1095
Stone G.'s Avatar
You probably have "long exposure noise correction" on, meaning that for each light frame, the camera will take a dark frame of the same exposure duration and subtract that dark frame from the light frame.
In the ist DL camera menu, go to "Custom Setting" and disable "Noise Reduction" in the second line from the top.
astronomy, astrophotgraphy, astrophotograhy, bill, camera, dslr, dss, exposures, f/1.8, images, lens, light, lights, lp, moon, night, night sky, photography, pk tether, post, settings, sigma, skies, stars, starscape, street, thanks
astrophotography with K-7 - issues =(. Please help? Nass Photographic Technique 40 02-10-2010 10:28 PM
Astrophotography with K10 J-Rod Photographic Technique 5 12-12-2009 06:08 PM
Astrophotography mithrandir Photographic Technique 1 11-26-2009 06:56 PM
K7 And Astrophotography Christopher M.W.T Pentax DSLR Discussion 49 11-25-2009 08:51 AM
Astrophotography elLuiggi Post Your Photos! 0 11-01-2007 05:43 PM
All times are GMT -7. The time now is 10:50 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
