Show Printable Version 294 Likes Search this Thread
06-13-2020, 08:31 PM   #1201
@Lucky IL - That is the best Witch Head I have yet seen. Congrats!
06-14-2020, 08:07 AM - 1 Like   #1202
Aaron28's Avatar
first time using the FA31 for 'astro' work with the K-1....paint rock alabama...reckon I should stuck around for it rise more as it was not visible to my eye
06-17-2020, 09:26 PM - 1 Like   #1203
QuoteOriginally posted by shiner Quote
It's so cool that you can actually see the moons of Jupiter with only a DA300 and 1.4x on a KP
Holy cow that's amazing! I need to get myself a 1.4x teleconverter and try this
06-18-2020, 06:47 AM   #1204
QuoteOriginally posted by Aaron28 Quote
Wow FA31 with K-1! That must be like the ultimate Pentax starscape kit! Your picture shows already great details in the MW. Imagine when it will be up and out of the light pollution!
06-18-2020, 07:36 PM   #1205
Aaron28's Avatar
QuoteOriginally posted by SunValley Quote
it's purdy nice...some trailing shows in the upper right.....I do like results with the FA35 as well...I would hafta look but I think that trailing occurs as well but not quite as noticeable
certainly need darker skies!!! and would have helped if I waited for it to rise more in the sky
08-04-2020, 12:00 PM   #1206
Praktica*ist's Avatar
Hello. There are a nice mix of humble, yet pleasing pictures, and very impressive pictures here.
So I would like to try astrophotography, and I'm planning to get an astrotracer O-GPS1 module.
Then, to get better deep red sensitivity, I would like to get a dedicated camera for the task, which would have its anti-IR filter removed and replaced by a more transparent one.
This modification would make the camera unsuitable for regular daylight use. So I would not inflict the treatment to my limited edition Pentax K5.
As the modification, which would be made by a professional, costs quite a bit of money, I'm considering one of those entry-level Pentax'es that have an aperture control block failure, those can be get for cheap second hand.
These partly faulty camera can only be used on manual mode with a lens having an aperture ring, but for an astrophotography use, this is not a problem.
Does this seems a pertinent idea to you ?
Which camera should I aim preferably ?
A 16 Mpixels K-30 / K-50 ? Or a slightly more modern K-S1 with 20 Mpixels ?
The K-30 / K-50 can function with AA / HR6 nickel-hydride batteries, a nice feature that K-S1 does not have.
08-04-2020, 01:26 PM - 1 Like   #1207
QuoteOriginally posted by NotMyFatDog Quote
The teleconverter is not needed, shot with a K-70/da*300
08-04-2020, 03:06 PM - 9 Likes   #1208
mikeSF's Avatar
'tis the season!
new stuff:
Martian Castle Magic (Explore #29)
645Z & 35mm
Knight's Ferry Bridge
645Z & 25mm
Comet NEOWISE (Explore #21)
645Z & 600mmx1.4
Timeless
645Z & 25mm
no astrotracer on the 645Z, but these are all multi-frames stacked and fed into Sequator.
08-05-2020, 05:20 AM   #1209
QuoteOriginally posted by Praktica*ist Quote
I shoot the stars with K-70 and K-5 and I don't personnally find the extra megapixels of the K-70 all that useful. With the astrotracer there is always a tiny bit of motion blur (center frame stars are rarely perfectly round) So a K-30/K-50 makes more sense unless you can find a K-S1 for the same price.
08-05-2020, 06:20 AM - 1 Like   #1210
Thank you for the advice.
There is also the fact that K-S1 / K-S2 / K-70 do not have anti-moiré filter, which makes the image theoretically a little bit sharper.
But it may not be significant, i don't know.
Is the lack of weather sealing a noticeable drawback at night (water condensation, mist) ?
---------- Post added 08-05-20 at 03:26 PM ----------
QuoteOriginally posted by mikeSF Quote
'tis the season!
new stuff:
645Z & 35mm
645Z & 25mm
645Z & 600mmx1.4
Timeless
645Z & 25mm
Dude, these photographs displaying the Milky Way with an interesting foreground are stunning. I like your last one with an old tree very much !
08-05-2020, 09:55 AM - 1 Like   #1211
Indeed but because of the slight motion blur, this advantage (and the extra megapixels)
is lost on stars. thinking about it now the K-S1/K-S2 and K-70 have 14 bit ADC while the K-30/K-50 have 12. This maybe an issue if you want to do intense histogram stretching as is normally done in deep sky post processing, the more information, the better.
'tis the season!
new stuff:
Thanks for sharing this, your work is so inspiring! That "Timeless" picture is one of of my favorite nightscape ever.
09-08-2020, 09:40 PM - 3 Likes   #1212
Aaron28's Avatar
4 frames (3 astrotracer).....messed up as it was not dark enough for the foreground shot so got a nice band of blue in there.......fa31.....K-1
09-23-2020, 09:36 AM   #1213
K1-II with Astrotracer, Sigma 50mm 1:1.4 EX DG HSM
F2.0 60 Sec ISO 800
Single shot with some contrast boost and correction for distortion, vignetting and CA in Lightroom:
Stack of 7 images with DSS:
At first I was getting some trails but then I realized I may have set up the camera too close to the car affecting the compass. I moved the car a few meters away, recalibrated and the Astrotracer was then spot on. The lens shows a bit of coma near the edges. It gets worse if I use it full open.
I need to learn more about stacking as I don't seem to get much improvement over the single images and colours get worse, even when shooting many more than the seven images in this example.
Last edited by lister6520; 09-23-2020 at 09:55 AM. Reason: Trying to get the images to show
09-24-2020, 01:02 AM   #1214
QuoteOriginally posted by lister6520 Quote
This could simply be because Pentax cameras are so good at astro-photography in the first place that they don't need the "benefits" of image stacking … especially with such a fast lens
11-01-2020, 08:07 AM - 2 Likes   #1215
Green&White's Avatar
The Pleiades. K1 ii & FA 2.8 135mm, ISO 1600, 37 x 30sec., ƒ4 plus darks and flats. Stacked with SiriL, PP with Affinity Photo
astronomy, astrophotgraphy, astrophotograhy, bill, camera, dslr, dss, exposures, f/1.8, images, lens, light, lights, lp, moon, night, night sky, photography, pk tether, post, settings, sigma, skies, stars, starscape, street, thanks
astrophotography with K-7 - issues =(. Please help? Nass Photographic Technique 40 02-10-2010 10:28 PM
Astrophotography with K10 J-Rod Photographic Technique 5 12-12-2009 06:08 PM
Astrophotography mithrandir Photographic Technique 1 11-26-2009 06:56 PM
K7 And Astrophotography Christopher M.W.T Pentax DSLR Discussion 49 11-25-2009 08:51 AM
Astrophotography elLuiggi Post Your Photos! 0 11-01-2007 05:43 PM
All times are GMT -7. The time now is 10:10 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
