08-31-2007, 10:00 AM   #1
Vivitar 2500 on K100D
Iíve just purchased a K100D and being on a well stretched budget am looking at using my old goodies with it. A screw mount lens adaptor makes the old lenses fit like a glove and a couple of test shots look great.
My question is the use of my Vivitar 2500 flash. Iíve read some earlier posts about voltage considerations but didnít see that anyone had any actual experience, I measured the voltage on the 2500 at 11.54 vdc. Someoneís previous post states that someone at Pentax said 25 vdc is the allowable max.
Is all of this correct? Does anyone have experience in using the Vivitar 2500 or similar flash around 12 vdc? I certainly donít want to fry my new treasure.
Thanks for any words of wisdom.
David
08-31-2007, 06:22 PM   #2
JCSullivan's Avatar
The Pentax recommendation was for the istD. I don't know what it is for the 100D.
Tel 1.800.877.0155 and ask them - they're really helpfull.
09-04-2007, 06:17 PM   #3
I called Pentax this morning and got the expected reply. I talked to Randy and he said that they don't have the specs on the maximum flash trigger voltage from Japan and that they don't recommend using anything except Pentax flashes.
I assumed that I would get that response, but thought it was worth a try since you spoke so highly of them.
09-04-2007, 07:07 PM   #4
JCSullivan's Avatar
Sorry about that David. Actually I think it was Randy that I spoke with as well - unless every male at that number is called Randy.
09-12-2007, 07:37 AM   #5
QuoteOriginally posted by JCSullivan Quote
Are you saying all the males at Pentax are randy?
09-13-2007, 10:49 AM   #6
If you want to use a flash with an unknown voltage, you should check out the Wein Safe-Sync hotshoe adapters. These reduce higher voltages to a safe level (6 volts). My local store carries them and if your's doesn't the major mailorder photo outlets do....like B&H, Adorama, etc.
Wein's link is: Safe Syncs
09-13-2007, 01:10 PM   #7
messthetics's Avatar
hmmm... I just acquired a Nikon F3 and it has a Vivitar 3200 on it, which I'm guessing is similar? I'm very interested in your findings.
09-14-2007, 03:05 AM   #8
Mike Cash's Avatar
QuoteOriginally posted by touchmyichi Quote
Make no assumptions regarding flash trigger voltage. TEST each flash before deciding to use it.
My Vivitar 2500 tested out to about 13.88v and works fine on the K100D.
My Vivitar 2000 tested out to somewhere around 228v and I wouldn't put it on a digital camera without a gun being held to my head.....and maybe not even then.
camera, dslr, experience, flash, k100d, photography, vdc, vivitar, voltage
Vivitar Thyristor 2500 K10D raystownboating Pentax Camera and Field Accessories 9 12-03-2008 05:27 PM
Tennis at ISO 2500 codiac2600 Post Your Photos! 10 07-23-2008 02:57 PM
For Sale - Sold: Vivitar 2500 thyristor zoom flash; 58mm soft focus filter drabina Sold Items 5 07-01-2008 05:18 AM
For Sale - Sold: FS: Vivitar 2500 Thyristor Zoom Flash Ed in GA Sold Items 0 10-14-2007 09:46 AM
Pentax FA 28-70 $2500 Wethphotography Pentax SLR Lens Discussion 22 01-31-2007 08:27 PM
All times are GMT -7. The time now is 12:26 PM. | See also: NikonForums.com, part of our network of photo forums!
