09-10-2010, 06:55 AM   #1
opiedog's Avatar
which to sell?
i have the kx and k200.
i want to upgrade to the kr or possibly the k5 but can't have 3 bodies specially at the higher introductory prices
i like my kx for its high ISO performance, fps and the k200 for the top lcd, quieter shutter, WR and GRIP!
which body should i put in the market? kx or k200?
09-10-2010, 07:00 AM   #2
dgaies's Avatar
QuoteOriginally posted by opiedog Quote
The Kr should have at least as good high ISO performance and fps as the Kx. However, as far as I understand it, the Kr won't be WR, have a top lcd nor a grip. So based on that, and for what you stated you use each of your current bodies for, it seems the Kr would replace the Kx and you should keep the K200D.
09-10-2010, 07:11 AM   #3
I am not in your exact situation, but I would sell the k-x and keep the K200D. The k-r does pretty much everything the k-x can do, while the K200D has features, notably WR and the top-LCD and grip shooting style (e.g. for flash work), that are different from and complementary to the small and light low-noise/high-ISO shooting style. As you know already, camera JPEGs can be much better out of the k-x than K200D, while up to ISO 400 or 800 there isn't much difference to the RAW quality or what you can achieve in pp.
You can replace your K200D with a K7 (or K5) when the price drops enough; that way you will be making another upgrade without compromise.
09-10-2010, 07:21 AM   #4
kari's Avatar
Obviously it depends on which body you're going to get. If I were you I'd sell the K200D if I got the K-5 and the K-x if I got the K-r. That way you always have a weather-sealed body and a smaller body which you can use depending on the situation.
Edit: Actually, I would just sell both and get the K-5. You can't shoot with more than one camera at a time anyway.
09-10-2010, 07:39 AM   #5
opiedog's Avatar
thanks for the inputs.
actually, i need 2 bodies since my wife uses the other body (mostly the k200)
a double upgrade would be nice, but realistically, that's not going to happen.
decisions, decisions...
camera, dslr, k200, kx, photography
50mm 1.2...to sell or not to sell? That is the question. RT1 Pentax SLR Lens Discussion 38 06-03-2013 04:13 PM
Film camera bodies - CLA then sell, or sell as is? SOldBear Pentax Film SLR Discussion 15 10-27-2009 04:18 PM
Sell or not sell, that is the question Taff Pentax SLR Lens Discussion 5 10-06-2009 06:19 AM
To sell, or not to sell... that is the question. rpriedhorsky Pentax SLR Lens Discussion 18 06-02-2009 10:23 PM
Which would you keep / sell? bwield Pentax SLR Lens Discussion 9 06-13-2008 07:14 PM
All times are GMT -7. The time now is 07:18 AM. | See also: NikonForums.com, part of our network of photo forums!
