I read the "Dirty Sensor?" topic, i did a search for "sensor cleaning" went 5-6 pages back.
Giottos wont dislodge the dust. repeated dust removal activations on camera wont remove the dust particle. And yes, the particle is on my photos but not visible in the viewfinder.
When i run dust alert the spec shows up in the bottom left of the screen, always there, laughing at my attempts to get rid of it.
Still have a couple questions.
Since i dont trust myself to wrap pec-pads without getting them contaminated, i have decided to get swabs to clean my sensor.
Question 1: Swabs come in difference sizes, what size should i get for my Pentax K-X, i see that Photographic Solutions has type 1, type 2, and type 3. What one do i get, none of them mention the K-x in the descriptions, just older models. Other brands put the sizes differently, as an example "1.3" "1.6". Again, which is the correct size for the K-X? I would rather the swab be the same height of the sensor to reduce the amount of strokes to clean it.
Question 2: I would try the Pentax O-ICK1 but thats 50 dollars or more depending on where you buy it from. Are there other cleaning items out there similar to the O-ICK1 but cheaper?
Question 3: Any DIY methods? I am pretty confident in my abilities. If someone else has successfully used DIY methods to clean your sensor please do tell.
EDIT: Wuestion 4: i realize that the spec of dust is actually on the bottom of the sensor and not the top since the image is flipped. Does the left side of the dust alert screen correspond to the left side of the sensor while i'm looking at the FRONT of the camera or the BACK?
Example of offending dust particle.
