09-02-2007, 08:29 PM   #1
*istD or *istDL2
I purchased both an *istD and an *istDL2 camera a few months ago. At first I felt the added features on the DL2 outweighed the advantages of the D, but after playing with them I am happy with the results from both. The SD ram in the DL2 is in more common use with other cameras and PDA's I own and reportedly it is faster than the CF ram used in the D but it doesn't 'feel' that way to me. The usb2 on the DL2 is also faster than the USB1 on the D but I find that I most always put the memory in a card reader anyway so that is a non issue. The pentaprism over the pentamirror is not something I see with my eyes so I cant say one way or the other on that.
I would like to here others opinions on this and welcome your input.
Thanks
Mike
09-02-2007, 10:33 PM   #2
The *istD does have some advanced features that the DL2 doesn't have, but since the DL is a few years older, it naturally has the advantages you listed above, including USB2, SD support, and a larger screen.
One of the main things that the *ist D boasts over all the other Pentax DSLRs is full TTL flash support. While the DS and DS2 partially support TTL, the *ist D even supports it with the on-board flash, meaning. The D also has several external buttons (similar to those of the K10D) whose functions have been moved into the menu on the *istDL.
There are a few other minor differences, but the D and DL2 are definitely not as similar as, for instance, the K100D and K110D.
*istd, camera, dl2, dslr, photography
Pentax *istDL2 Ole Pentax DSLR Discussion 3 12-08-2010 11:07 PM
AF360FGZ Flash with *istDL2 dangie Flashes, Lighting, and Studio 1 05-18-2008 12:22 PM
Problems with updating my *istDL2 HenrikSchafranek Pentax DSLR Discussion 0 03-20-2008 10:50 AM
Updating my *istDL2. HenrikSchafranek Pentax DSLR Discussion 0 03-20-2008 10:14 AM
Doesn't anyone own the *istDL2? slip Pentax DSLR Discussion 5 11-14-2006 04:23 PM
All times are GMT -7. The time now is 11:17 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
