Making dvds with 24fps K-x footage but only 23.97fps option in DVD Architect
So the k-x makes videos that are 24 frames per second. I edit using sony vegas 9. So when i edit and render the file i make sure its all 24fps not 23.97. However, when i go to make the dvd using dvd architect, i only have the 23.97 option and not a 24fps. I've made the dvd with 24fps and can't seem to tell the difference.
My question is. Will using the 23.97 when authoring the dvd cause noticeable problems that i may not be catching? Is there a way around it?
thanks
