Originally posted by mtroute As for the FL, I am a huge user of the "Normal" range. Most of my shots fall right into the 30mm range give or take. I also do a lot of photography indoors and the F50 1.7 gets a lot of use but tends to be a bit long.
Based on the above I'd say go for the FA 31mm LTD.
There's not many better 'into the 30mm range give or take'.
Just a step or two forwards, a step or two backwards - and you got it covered.
The K-5 will get cheaper soon. The 31mm should at least hold it's value.
At least you have a fun decision to make
Cheers,
Rod.
