09-23-2010, 06:58 PM   #1
Tim_R's Avatar
In-camera vs. in-lens shake reduction (power usage)
There is one aspect of the in-lens vs. in-camera SR debate that concerns me: power requirements.
It seems to me that rapidly moving ANY mass requires battery power. The larger the mass and/or the greater the distance it must be moved, the greater the power requirement.
Without a LOT more technical information, it would seem to me that the impact on battery life should be least when moving a lightweight sensor rather than shifting a probably more massive lens element(s). And as a guess, I suspect that the distance a lens element must be moved for SR is likely to be greater than the distance a sensor must move to accomplish the same thing.
I ran across this link on the "advantages" of Nikon's in-camera VR: Vibration Reduction from Nikon
Of course, as that Nikon publication points out, the VR algorithm in a Nikon lens can be optimized for that specific lens. To accomplish the same in a Pentax requires that the camera software have database data for every Pentax lens out there, a method to update the database, and some default values for all other lenses.
I have not seen this possibility discussed anywhere, but it is food for thought.
Tim
09-23-2010, 07:00 PM   #2
Check out this thread: https://www.pentaxforums.com/forums/pentax-beginners-corner-q/115170-body-sha...hake+reduction
battery, camera, database, distance, dslr, in-camera, lens, nikon, pentax, photography, power, sensor, vr
Trying to set the lens mm for shake reduction gary1952 Pentax DSLR Discussion 26 07-14-2010 02:32 PM
camera shake reduction Wes Pentax DSLR Discussion 26 04-20-2010 12:19 PM
Shake reduction w/ 105mm lens ? kathyk Pentax SLR Lens Discussion 3 05-26-2007 04:29 PM
in-camera shake reduction vs in-the-lens WMBP Pentax DSLR Discussion 17 02-23-2007 09:13 PM
Shake reduction & camera life Brew1brew Pentax DSLR Discussion 9 09-27-2006 05:58 AM
All times are GMT -7. The time now is 04:37 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
