09-23-2010, 10:03 PM   #1
str8talk83's Avatar
running dual systems?
I'm currently a Canon user, but have been considering Pentax for their weather sealed body and quality optics at a reasonable price. The only problem, is that I generally shoot wildlife and my 400L lens is so good that it will be hard to give up. I have been considering selling one of my 40D's and getting a lens or two to try pentax out. Here are my options.
Sell one 40D (around $500) and my 17-55 IS (around 850). This will give me $1350 to throw around. What would be the best way to try out the Pentax system? I have thought about getting a K-7 and then a FA 43 Limited lens to start out with. Thoughts?
09-23-2010, 10:07 PM   #2
wlachan's Avatar
Lenses not labeled WR is not WR, FA43 included. Going into Pentax is fine, but make sure not for the wrong reason. You won't find 17-55IS quality from Pentax btw, just in case you didn't know.
09-23-2010, 10:11 PM   #3
str8talk83's Avatar
QuoteOriginally posted by wlachan Quote
I guess that I made an erroneous assumption that the Pentax DA 16-50 was in the same league as the canon 17-55. Thanks for the info on the weather sealing as well.
09-23-2010, 10:21 PM   #4
wlachan's Avatar
Other than not WR, the 17-55IS is pretty much the best money can buy for APS-C.
09-23-2010, 10:24 PM   #5
str8talk83's Avatar
It is an excellent lens. I have stopped using the 50mm f/1.8 completely because the bokeh and autofocus sucks. This is (in my opinion) the best standard zoom available for Canon system. I was hoping that the Pentax DA 16-50 was similar...
09-24-2010, 02:43 AM   #6
photozone test of the 16-50:
Pentax SMC DA* 16-50mm f/2.8 ED [IF] SDM - Review / Test Report
vs
17-55
Canon EF-S 17-55mm f/2.8 USM IS - Review / Test Report
and d40 sensor vs k-7 :
DxOMark - Compare sensors
So as you can see going from a 40d 17-55 to a k-7 with 16-50 would be a downgrade.
09-24-2010, 03:38 AM   #7
If you look at the following measured / tested reviews:
Canon Lens: Zooms - Canon EF-S 17-85mm f/4-5.6 IS USM (Tested) - SLRgear.com!
the 17-55 does not do out very well.
Unfortunatly they did not test the 16-50mm, for which I am very content having.
- Bert
09-24-2010, 03:41 AM   #8
wlachan's Avatar
17-55 & 17-85 are 2 different lenses.
09-24-2010, 04:41 AM   #9
Frogfish's Avatar
QuoteOriginally posted by WerTicus Quote
vs
17-55
However even more interesting is that on that very same DxOMark comparison the Kx's sensor knocks the socks off of both the D300s and the 7D !! And the K5 is a big step up again in terms of DR & ISO performance.
Can't wait to see the K5 in the flesh then all the speculation can stop and the real debates begin
09-24-2010, 10:02 AM   #10
str8talk83's Avatar
Two VERY different lenses. 17-85 is good "bang for your buck" but has a lot of optical flaws and the build isn't as good even though they are both EF-S.
Sounds like I'll be waiting until the K-5 to make any moves.
09-24-2010, 12:21 PM   #11
Miguel's Avatar
In the Canon world, research the mediocre reception that the Tokina 16-50mm received. They are sister lenses. The 50-135mm however, is much better. I use it happily on my 7D.
M
09-24-2010, 08:52 PM   #12
Honestly, if I had that glass, I wouldn't be looking into getting started on any other system, unless I was really unhappy with the Canon lineup. I would be looking into upgrading the camera body if that would help -- and boy, you have a lot of great choices there -- or I would be considering another superb lens -- more choices from Canon and third-party manufacturers. Enjoy. (BTW I have no Canon gear, and I am invested way too much in Pentax stuff, FWIW).
09-24-2010, 09:03 PM   #13
QuoteOriginally posted by Frogfish Quote
We don't know if the k-5 will be better than the k-x at all... pure speculation.
I wouldn't say the K-x knocks the socks off the 7d, but it is better.
09-24-2010, 09:04 PM   #14
Moving to Pentax. Autofocus downgrade. If I am not mistaken aren’t the great white lenses weather sealed.
09-24-2010, 09:39 PM   #15
str8talk83's Avatar
QuoteOriginally posted by montman Quote
Not all of them are. Here's a weather sealed list.
70-200 f/4 IS
70-200 f/2.8 IS (version 1 & 2)
300 f/2.8 IS (version 1 & 2)
400 f/4 DO
400 f/2.8 IS I & II
500 f/4 IS
600 f/4 IS
800 f/5.6 IS
300 f/4 IS and 400 f/5.6 IS are not sealed. Neither is the 100-400 f/4.5-5.6 or 28-300
camera, dslr, lens, pentax, photography
I may change systems Kevin B. Pentax DSLR Discussion 9 09-20-2010 04:36 PM
If you were to switch systems. What would it be? throndor General Talk 97 02-16-2010 06:54 AM
K-x Dual lens kit mamba909 Pentax DSLR Discussion 5 11-14-2009 12:22 AM
A Tale Of Two Systems brumby Pentax DSLR Discussion 54 04-26-2009 10:34 AM
Dual Battery Charger Mark Castleman Pentax DSLR Discussion 5 07-10-2008 12:03 PM
All times are GMT -7. The time now is 05:18 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
