Originally posted by wjwncpro Hi Lance,
Prior to the DS2 software update, the DA 16-45 underexposed -0.5EV on my DS but with the Katz Eye w/split&grid exposes right on. I took out the Katz Eye a few months ago prior to getting the update and since then (with the update / without the Katz Eye) the 16-45 exposes as should. I just put the Katz Eye back in this past weekend and I'll try to get some pics this Sunday with the 16-45 and see how they come out.
The reason for the Katz Eye exposing correctly on the DS is due to the split prism and microprism collar. I will elaborate.
Brett and I did some extensive testing with the Katz Eye in the D and found that with darker lenses like the DA16-45 f4 and the FA300 f4.5, one half of the split prism, and also each half of the tiny little microprism collar prisms, would go dark. This had the affect of fooling the cameras meter into thinking there was less light than there actually was and so the camera compensated by giving extra exposure. We found that it affected exposure by about 0.7EV.
Spot metering with the Katz Eye was unuseable IMO.
I sold my Katz Eye as it gave too many variable results with the DA16-45 and FA300. I sold it to a forum member who was having underexposure issues with his DS and DA16-45 and it worked for him too.
I think the firmware update for your DS addressed the ORIGINAL underexposure issue and probably made the DS expose correctly like the D does. You may find now that you will have the same problem as Brett and I did with our D.
The DA16-45, like all the new DA/DFA lenses, was one of my most consistently correct exposing lenses. I could always rely on it and I used it as a sort of "standard" by which I judged all other lens exposure. All the FA/FA* lenses generally needed -0.30EV dialled in when used on the D.
The Katz Eye used in the K10D did NOT have any split prism or microprism collar and was effectively just the ground glass screen with 1/3rd grid lines, almost identical to the Pentax LL60 focus screen(which also doesn't work in the K10D). I therefore wonder how it can affect the exposure on just two lenses, but not the others. Maybe the ground glass screen has a slight effect like the Katz Eye with split prism and microprism collar.
