Originally posted by er1kksen I wouldn't be so sure about the K10D offering better imaging qualities at ISO 100... the K-x is fantastic at ISO 100, with so much clean detail in the shadows I thought I had died and gone to heaven when I first opened a file. Whatever sensor design improvements give the K-x such good high ISO performance certainly applied to the rest of the ISO range as well.
Not sure if I completely agree with this. I currently have BOTH K10D & Kx (besides a K100D Super).
For normal day life, everyday shooting, the very compact Kx is mostly the choice for me, and along with the 40mm Pancake or 35 FA, it is very compact and it is great to carry it around. It is the perfect camera for everyday shooting.
BUT, whenever I am doing "professional" work (I do get some paid projects now and then) the K10D is usually the choice, UNLESS I need high ISO (Kx is in a totally different league here, not a secret).
For some reason, I also noticed the low ISO on the K10D to be somehow more vivid. It is very weird, because at first I thought something was not set correctly on the Kx, but then I realized the K10D does offer some very good quality ISO100 shots. The colors are better on the K10D. The Kx somehow does not render "Pentax Colors" like the K10D, using the same lenses.
Not sure why. Maybe is it the CCD x CMOS techology difference? Dont ask me, but I have notice that.
I think the main advantage for the Kx is indeed high ISO and size. If the OP needs either, then you have the winner. But if NOT, then definitely the K10D (or even the K20D) would be a nice option. But be careful, I never use ISO above 400 on the K10D.. it is that BAD... while I safely use 1600 on the Kx.
