Originally posted by JamesD ...
In the intervening years I've been generally displeased with the results. I knew beforehand that the designer of this camera had programed in algorithms that would make the images have a more natural, film-like quality and lack that punch that some camera makers opt for.
However, I've reached a place where I'm now considering selling our Pentaxes and going with something else. The images we produce seem too dead, flat, dark. By way of comparison, I picked up a Panasonic Lumix from Costco (DMC-ZS6) and immediately found the images to be far clearer and bright overall.
So, obviously I must be doing something wrong. That's why I've decided to ask here before making my final decision.
What settings do most of you set your cameras at for general photography (scenic, landscape, nature) OR do you leave it at the default settings?
Is the Tamron lens a culprit in my imaging woes? Would I be better advised to spend money on a different lens covering a similar range?
I understand that I will need to do some post processing of my images, but I don't want to spend an inordinate amount of time. My feeling is that the images I shoot should be, more or less, close to what I want to show to others.
For your information: I seldom shoot in RAW, preferring fine JPEG. I'm not very accomplished with post processing techniques (we have Photoshop Elements 8) and would hope that my images in camera would at least be close to acceptable for viewing. Right now... they're dead-looking.
The problem is, that you compare apples and pears. A compact camera is tuned to give over-sharp, over-saturated colours, because many people have been educated by advertising (even back in film times), that this is desirable. This is not limited to photography but to all aspects of consumer products.
A DSLR on the other hand is less of a consumer product. Some basic modells will work an provide results similar to a point-and-shoot camera - but the K10D isn't a basic camera, it is a near-professional tool. And as with any professional tool, you need to know how it works and how to apply it.
You can tweak JPGs a bit by increasing saturation and sharpness, to achieve JPG-results similar to a point-and-shoot camera. But the K10D works much better, if you know, how to use it.
I see, that you don't want to spend much time with post-processing. I symphathize. But if you use one of the more workflow-oriented RAW software packages, like Lightroom, Aperture or Capture One, you will see, that (after the initial learning phase) you can automate or semi-automate most basic enhancements. Thus editing even large numbers of files is quite fast,
Ben
