Originally posted by r0ckstarr On my Pentax 18-250, it has been sharp and in focus between 18-150mm, but I have noticed that overtime anything from 150-250mm is getting worse as far as AF is concerned.
Would this be a reason to calibrate? If so, how do I calibrate the long end of the lens without changing the focus between 18-150mm?
No, it is not that the lens is more off long than wide. It has to do with the Depth of Field, which is a factor depending upon lens focal length, subject distance and aperture.
Depth of Field is shallower for longer lenses.
Let's do an example:
For a subject at 10 meters (focused at), with 18mm at f 3.5, your DOF is between 3.5m till infinity.
For the same subject at 10 meters, with 250mm at f 5.6, your DOF is
only 9.83m till 10.2 meters!
So, if your AF would be off by 0.5 meters, you will probably not notice that that at 18mm, but all your pictures at 250mm will be out of focus...
See also:
Online Depth of Field Calculator
So, you will need to recalibrate I guess....
- Bert
