Originally posted by keithross39 the only way it will fire every time is if the on camera flash fires. is there a way to make my K10 produce the trigger signal consistently, with the on camera flash in idle mode?......thanx in advance
As others have said, 1/180s or slower is required or no signal generated. On camera flash when extended automatically reduces shutter speed to 1/180s thus solving the problem without you realizing what actually is going on.
BTW, on K10D mode dial you have "X" setting for flash. Set to "X" and forget about shutter speed, it will be locked to 1/180s. (As with any flash you regulate exposure only by changing aperture.) I am using "X" with studio lighting with no problem, or "M" if I need to balance flash with ambient light outdoors (indoors mostly does not matter, "X" does the job).
And NEVER use external strobes with manual power regulation with camera modes other than "X" or "M" or you won't be able to fully control results at all.
