10-09-2010, 03:58 PM   #1
Squier's Avatar
CIF worked yesterday, but not today
I cant see whats going wrong here.
Using a fully manual lens ( M42 + Unflanged Rainbow adapter ) Using either M or Av.
I have CIF enabled, Use Aperture Ring enabled , AF-S enabled. Flash off, no EV set, no bracketing, but the shutter will fire 3 times if I keep my finger on the trigger, whether in focus or not. That doesnt sound right
Anyway, yesterday CIF works like a charm, today the shutter fires soon as its pressed.
User error is always the first port of call, so have I unconciously set something wrong ?
10-09-2010, 04:08 PM   #2
Did it work like a charm with the exact same set up? From what I've read, when using a flangeless adapter, you have to short the contacts on the camera lens mount in order to use CIF with an M42.
10-09-2010, 04:16 PM   #3
Squier's Avatar
Hi Jeff - yes same lens with that same adapter. Cant figure it out.
10-09-2010, 04:27 PM   #4
Well, I'm out of ideas. Unless that is, you changed the camera from AF-S to one of the other focus modes. CIF only works with Center spot focusing (IIRC) and AF-S. Even then however, the camera will just fire regardless of focus (in AF-C and MF).
Edit:
Sorry, I didn't read your entire post correctly (have to correct that).. You said..
Are you sure you don't have your Drive mode set to Continuous?
10-09-2010, 04:46 PM   #5
agsy's Avatar
Did you check to make sure the AF/MF switch is in AF position?
10-09-2010, 05:24 PM   #6
Squier's Avatar
Jeff - where's continuous mode in the menu ? Spot was used, and centre AF too. Its been set that way since I bought
the camera a couple of weeks back
Agsy - yes checked that, set on AF, so that was ok
10-09-2010, 05:40 PM   #7
Squier's Avatar
Jeff - silly me, i found it. Its set to AF-S. I was sure it was, but i started having doubts. So it wasnt that anyway
10-09-2010, 05:54 PM   #8
Squier's Avatar
Checked again - and again. Still firing as soon as shutter is pressed, and still firing off more than one shot if my finger is left pressed on the shutter. And that is definately with AF-S enabled, not AF-C
10-09-2010, 06:03 PM   #9
agsy's Avatar
Are you saying that the camera is firing three shots? Is it in HDR mode? Or maybe bracketing? I know that when I used Takumars I had to make sure about the 6 'o clock pins to be shorted. I'm sure you checked that. Can't think of anything else...I have a K-x which might be a bit different.
10-09-2010, 06:14 PM   #10
Squier's Avatar
I'm not sure i have an HDR mode on the 200D, but here's a thing.
I just swapped lenses for another - my Tamron SP 90 f2.5, the old one. Got a genuine Tamron PK adapter. CIF just worked fine!
So i think you guys are right about the shorting i think. The last contact button must need covering or something. Cant figure out why it worked with the other lens yesterday, and not today. I didnt short any pins then.
One thing though - its still firing 3 shots. Thats a maximum , as I just left my finger on the trigger to see how many it would take, and it stopped at 3. No bracketing used
10-09-2010, 06:29 PM   #11
agsy's Avatar
I found that shorting the contacts using the Takumar it helped tremendously in metering. It would constantly underexpose (in Av mode) without having the contacts shorted. Good luck finding the issue.
10-09-2010, 06:37 PM   #12
Squier's Avatar
yes, i guess this one lens must need it, but why it didnt need shorting the other day is a bit of a headscratch.
And i'm still going through the manual wondering why i'm getting 3 continuous shots, when continuous hasnt been enabled.
10-09-2010, 06:45 PM   #13
agsy's Avatar
I jut looked it up and there is HDR shooting on the K200D (3 types). However, on the Kx if you are shooting HDR, you press the shutter once and it will fire all three shots even if you release the shutter after the first shot.
10-09-2010, 06:47 PM   #14
Squier's Avatar
Isnt HDR only available in Playback Mode on the 200D? It looks like its just some filters that can be applied after the photo has been taken
10-09-2010, 06:48 PM   #15
I think you're confusing Continuous AF (AF-C) with Continuous Drive Mode (pg 115 in your manual). I'm specifically addressing the 3 shots in a row here.
camera, cif, dslr, photography, shutter, yesterday
Has anyone here worked on a KX meter? Sluggo Pentax Film SLR Discussion 17 05-07-2010 05:05 PM
Got my K-x Yesterday, and it's Going Back to B&H Today - Known Battery Problem wll Pentax DSLR Discussion 24 11-01-2009 12:33 AM
yesterday or today? dcmsox2004 Post Your Photos! 5 09-07-2009 07:45 AM
Re-worked in lightroom Jimbo Post Your Photos! 12 09-20-2008 03:45 PM
hope it worked! stern Monthly Photo Contests 2 04-24-2008 11:20 AM
All times are GMT -7. The time now is 03:19 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
