10-09-2010, 10:53 PM   #1
Squier's Avatar
K200D Metering - something i miss
The metering bar on my previous Canon is something i really miss on my K200D. Overall, i love this camera more than my Canon, but that metering bar was excellent to see in the viewfinder all the time. Over or Under exposure was seen at a quick glance
I know this is a K10D image, but the Canon was identical
10-10-2010, 03:18 AM   #2
Maybe you need a K10d?? 10d and 200d use the same CCD anyway
10-10-2010, 03:56 AM   #3
Squier's Avatar
I had one about 18 months ago, and i much prefer the K200.
Hey, cant have everything I suppose
10-10-2010, 06:42 AM   #4
ytterbium's Avatar
You're really talking out of context. Some additional details would be required to understand how can we help you.
Because of this i'm GUESSING, that you're talking about exposure in manual mode. Otherwise you'd be saying compensation instead of over/under exp..
As far as i can tell my k200d in manual mode always indicates expousure deviation by EV number. Maybe there was some custom setting to enable this? I remember only choice between remaining shots and ISO.
Yes, in other modes it's not displayed all the time. Still, when you apply some compensation, the number stays on LCD as long as it is applied. The top LCD also displays the [+/-] icon.
This way you can still see straight away, when some compensation is applied. A quick click on the [+/-] button allows you to confirm, if no EV has been applied.
So i'm not sure what you're actually missing. EV Indication at all times?
IMHO it exists only in a different way.
10-10-2010, 08:30 AM   #5
I believe he is saying that he prefers the bar graph type meter instead of the +/-. Nothing real difficult to understand about that. No guessing required. Especially since he shows a picture of what he is commenting about in his first post.
10-10-2010, 08:56 AM   #6
Squier's Avatar
Thanks Jeff
K10 and Canon 40D i've owned just seem more ' instant '
+/- doesnt indicate how much +/- there is. Just that its +/-
In an instant, a bar graph is showing you by HOW MUCH you're metering is above or below zero. Simpler and it works.
This helped a great deal when using strange lenses that i've owned that needed under exposing by 1 or 2 points below zero on the bar.
10-11-2010, 03:56 PM   #7
On the right by the left of the hand there is numbers there. Put it in man. mode move camera around and they will change or hit green button and it will 0 that is perfect now turn dial and you will see it change +3.0 2.0 or -3.0 20. above 0 that is the meter.When at 0 you are good to go.
10-11-2010, 04:23 PM   #8
Squier's Avatar
When looking at the metering in Manual / Av, i dont see those numbers changing + 3 , +2 , - 2, - 3
I see ISO number
10-11-2010, 09:34 PM   #9
Go to Full Manual, "M" on the dial. The numbers appear in the right hand corner of the viewfinder.
BTW you can still see those numbers, and add compensation or subtract it, by pressing the Av button and rotating the e-dial in any Scene or Exposure mode except Manual and Bulb. (In Manual mode it appears at the right side automatically.) So, you have your numbers (but not a graph as with the Canon) for exposure compensation in Shutter and Aperture Priorities as well.
10-12-2010, 04:33 AM   #10
Squier's Avatar
In manual, as i said, i dont see +3 +2 - 3 -2 I see ISO 800 / 400 etc
I mentioned strange lenses a few posts back. By that i mean MF lenses, like the Avanar M42 135mm, Tamron 90mm macro, etc
10-12-2010, 04:43 AM   #11
ytterbium's Avatar
Probably you need to set custom function "Display Sensitivity 1: Off
2: On" To Off.
Then set OK button to show sensitivity if required.
10-12-2010, 04:51 AM   #12
Squier's Avatar
Ok, will try that now, thanks dude
10-12-2010, 04:55 AM   #13
Squier's Avatar
Ok, that didnt work either. Instead of ISO displayed, i now see number of shots left on the card.
I probably need to set another custom function - i'll check
10-12-2010, 10:09 AM   #14
I think that you have to tell the camera, in the Custom menu, which EV steps you want (1/2 or 1/3). Once the camera "knows" that you want to use it, the numbers will appear in the right of the screen automatically in Manual mode (but not automatically in AV or shutter priority or program modes). If you don't set the EV comp. steps, the camera will display something else there (ISO or shots remaining?)
10-12-2010, 10:17 AM   #15
Squier's Avatar
I have 1/3rd EV already set, so its not that . I will keep checking things out - thats the beauty of a new camera
So much to learn
bar, camera, canon, dslr, k200d, photography
Struggling with metering, k200d ytterbium Troubleshooting and Beginner Help 14 04-08-2010 12:07 AM
K200d: Incorrect metering in low light conditions? flamenco Pentax DSLR Discussion 29 11-28-2009 02:50 AM
Does the K200D metering tend to favor the right side of the histogram? joeyc Pentax DSLR Discussion 7 06-26-2009 12:06 PM
k10D metering with M lenses in M mode - K200D doing a better job w/ Green button mrpackerguy Pentax DSLR Discussion 8 10-03-2008 11:53 AM
What I miss (and don't miss) about my K10D switters Pentax DSLR Discussion 35 01-06-2008 02:51 AM
All times are GMT -7. The time now is 08:48 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
