10-10-2010, 07:47 PM   #1
bwDraco's Avatar
K-r vs. K-x in high ISO performance
How do the Pentax K-r and K-x compare in terms of high ISO performance? Is there any improvement or difference in terms of noise levels? Thanks,
--DragonLord
10-10-2010, 08:41 PM   #2
causey's Avatar
I haven't seen any direct comparisons yet, but early reports say K-r is visibly better than K-x with respect to ISO performance. I guess we'll have to wait for actual comparative reviews...
10-10-2010, 08:58 PM   #3
Too early to tell. Eventually sites like DXOMark will reveal all.
It's likely they will be similar though.
10-10-2010, 09:13 PM   #4
JohnBee's Avatar
If we need DxONMark to tell us, then I don't think there is much to talk about
10-10-2010, 10:57 PM   #5
Maybe I just have a thing about French guys in lab coats. We all have our weaknesses.
10-11-2010, 12:02 AM   #6
Steelski's Avatar
You need to get that looked into, DXO also tells us that the Nikon D90 performs better than K-x, whilst a visual inspection at 6400 will tell you otherwise
10-11-2010, 03:46 AM   #7
QuoteOriginally posted by Steelski Quote
DXO also tells you that the K-x NR kicks in at ISO 3200 and from there on beats the D90 in signal to noise ratio. So read the curves and everything turns out just fine.
10-11-2010, 03:50 AM   #8
Stefan Carey's Avatar
Ignore this post, what I was about to say was not interesting or funny , and the photo I was about to add was also not that interesting. I am spending too much time here in anticipation of the K-5.
10-11-2010, 04:53 AM   #9
QuoteOriginally posted by Gimbal Quote
Even if the nr kicks in, the k-x delivers more detail and less noise
10-11-2010, 05:51 AM   #10
Even if they Kr is just a little better, the kx already has pretty impressive DR and noise control. It is hard to believe that we are not getting close to the limits of what is capable in an APS-C size sensor.
12-10-2010, 07:30 AM   #11
I owned a K-x and sold it to get a new K-r . The K-r AF speed is better, but I don't think the K-r is better than K-x at the hi ISO performance, the K-x is slightly 'cleaner' .
12-10-2010, 01:11 PM   #12
audiobomber's Avatar
QuoteOriginally posted by sonnief Quote
The only comparo I saw showed no difference in noise between the K-r and K-x. The K-x images looked very slightly more detailed. It appears the improved sensitivity is limited to the K-5, the K-r didn't benefit.
12-10-2010, 02:58 PM   #13
Ira
The K-x's noise reduction, and the K-r's as well I assume, kicks in when you TELL it to kick in via your preference settings.
And you can totally turn NR off anyway at all ISOs.
So:
Huh?
12-11-2010, 10:56 AM   #14
QuoteOriginally posted by causey Quote
Be grateful for links to your references please?
There has been a thread in the K-r forum:
anyone did Kx to Kr?
take a look at Post #18 -
the links to the direct comparison photos seem to show that there was very little difference between the new K-r and K-x.
The referred direct comparison photos thread was by devorama:
K-r vs. K-x ISO samples (or return of the ISO flower!)
The direct links to devorama's side-by-side ISO flower comparisons
All sizes | high-key_ISO_elevator | Flickr - Photo Sharing!
All sizes | low-key_ISO_elevator | Flickr - Photo Sharing!
All sizes | grey_ISO_elevator | Flickr - Photo Sharing!
FWIW -
Later on in the thread in Post #23 direct comparison taken from dpReview of the K-x with the current top hotshots Canon 60D, Nikon 7000 and Pentax K-5 at ISO6400 and 12800 - show how well these new hotshots are doing against the K-x which is/was the leading HighISO APS-C.
12-11-2010, 11:06 AM   #15
causey's Avatar
The referred direct comparison photos thread was:
The direct links to devorama's ISO flower comparisons
FWIW -
Later on in the thread in Post #23 direct comparison taken from dpReview of the K-x with the current top hotshots Canon 60D, Nikon 7000 and Pentax K-5 at ISO6400 and 12800 - show how well these now hotshots are doing against the K-x which is/was the leading HighISO APS-C.
My post is quite old--I was reporting the early conclusion of someone who had made a comparison; I think later the same person disproved that conclusion. In light of newer comparisons, it appears there is no difference btw. K-x and K-r.
camera, dslr, iso, k-r, k-x, performance, photography, terms
Boosting High ISO Performance Jewelltrail Pentax DSLR Discussion 30 10-10-2010 10:26 PM
K-7 high ISO Performance RAW shang Pentax DSLR Discussion 28 07-04-2010 12:27 PM
K20D High ISO Performance joelovotti Pentax DSLR Discussion 22 03-17-2009 06:47 PM
K200D low light/high iso performance indytax Pentax DSLR Discussion 22 02-07-2009 07:49 PM
Better high ISO performance on "K20D"? switters Pentax News and Rumors 39 12-02-2007 01:06 PM
All times are GMT -7. The time now is 01:43 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
