Originally posted by JohnBee The K-7 has very good DR at nominal ISO (100-200 range).
All you need to do to tap into it, is shoot in RAW and preserve your highlights.
You'll have no problems keeping-up with a D700 FF.
It's true. THe K-7 has extraordinary amounts of information in the shadows. And more importantly, when shooting RAW, it has the kind of information that can be pulled out pretty aggressively without adding much noise. And the noise reduction in LR3 is so much better than LR2, and it sure seems to have the K-7's number in this regard. Since switching to LR3 and getting pretty aggressive with pulling out shadow detail and applying moderate NR to smooth things out. It's not uncommon for me to crank the Recovery, pull the exposure slider way back, push the brightness over 100, put the Fill Light over 50 the Blacks up to 40 or so, apply a little bit of NR and sharpening, and have an image that looks great at 100%, of a scene that looked like it should have needed HDR.
Like JohnBee said, just make sure you preserve the highlights, and you'll be surprised what you can pull out of the shadows. Just be careful that you don't delve too greedily and too deep. There are older and fouler things than orcs in the deep parts of your image.
