09-15-2007, 01:27 PM   #16
To original poster: did you fully charge the batteries the first time before using them? This is very important. It fits your description, and I know at least 1 person who had a similar problem (he didn't charge the first time, and now the battery is dieing within 1 hour)
Hmmm, it seems some people here have adopted very wrong practices with their batteries...
Eneloops can be used straight out of the pack
GWP mentioned a good feature on a charger - make sure it can discharge
That's actually ranges from indifferent to harmful (in-camera discharge is the best btw), as it can decrease capacity if you don't know what you're doing.
I could translate an amazing battery FAQ, if I get the permission from the writer. I think similar guides must also exist on the web...
09-15-2007, 02:52 PM   #17
Mallee Boy's Avatar
QuoteOriginally posted by Antitrust Quote
G'day Antitrust,
With respect, may I direct you to SANYO eneloop | Ready to use Rechargeable Battery - The only battery you will ever need: Home
That will provide you with a little more information, which also states quite clearly that they are ready to use, straight out of the packet.
Cheers
Grant
09-15-2007, 04:34 PM   #18
Jimsi777's Avatar
You are referring to the memory effect of a battery, this applied to older 'Nickel Cadmium' batteries, the ones we use now doesnt have this memory effect, ours can be charged even when 1/2 discharged without harm ...
09-15-2007, 06:02 PM   #19
Stratman's Avatar
I just bought a 4 pack of the Ray O Vac hybrids, going to see how they hold up compared to the Eneloops.
09-16-2007, 01:06 AM   #20
stewart_photo's Avatar
QuoteOriginally posted by Jimsi777 Quote
Actually, I don't think the member "Antitrust" was referring to that. Lithium, NiMh, and similar batteries, are typically shipped with the internal chemistry in a neutral state to avoid degradation during shipment and while sitting on store shelves. The initial charge after purchase excites the chemistry, with how well that's accomplished impacting overall battery performance. This is why the manufacturers of these battery so strongly stress that first initial charge.
Afterwards, these batteries can indeed tolerate a lot of abuse, including repeated partial discharge/charge cycles without the so-call memory effect. However, this type of usage is not really the ideal for any battery.
The Sanyo eneloop batteries (and similar) are the rare exceptions to all this, not the norm. These are shipped from the factory with the chemistry already excited, therefore less dependent on that the initial charge by consumers. My main concern with these batteries would be how well Sanyo has truly overcome the usual degradation during the time period between the factory and the end consumer.
stewart
09-16-2007, 07:03 AM   #21
Would be very interested in seeing this .
However, in the meantime, there is a very good resource that seems authorative on the subject.
BatteryUniversity.com
the section of relevance - since mostly when we are talking about rechargeable batteries for the K100D - it's the NiMH -
Charging nickel-based batteries
Charging nickel-metal-hydride section is about 2/3 down that page.
LSD (Low Self Discharge) batteries are based on NiMH but have extra circuit built-in that reduces the discharge rate (hence the name).
Sanyo eneloops are the most well known as they were the first - other brands are RayOVac Hybrid, and Kodak Pre-Charged (the latter 2 are NOT re-badged eneloops, but different designs - reports say they also perform well). All of these are advertized to be usable straight out of the pack, without needing an initial charge - people who have tested them say they have about 85% of full charge fresh out of the pack.
camera, charge, dslr, life, photography
AA battery life jslifoaw Pentax DSLR Discussion 54 06-05-2011 05:26 PM
AA battery life with video m_austin_j Video and Pentax HDSLRs 3 11-24-2009 07:38 AM
Battery life K20d? ennoia Pentax DSLR Discussion 6 06-15-2008 10:00 AM
battery life m.orp Pentax DSLR Discussion 1 04-21-2008 08:10 PM
K100D battery life wildherre Pentax DSLR Discussion 23 12-12-2007 11:58 PM
All times are GMT -7. The time now is 07:25 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
