10-16-2010, 10:15 PM   #1
k7 SR malfunction
[YT]http://www.youtube.com/watch?v=51981fDGwZ4[/YT]
serious problem on my k-7 remote bulb mode
it's sporadic and i dont know how to do with this....
10-17-2010, 01:29 AM   #2
tomwil's Avatar
A low battery can cause erratic behavior such as this.
10-17-2010, 01:39 AM   #3
PFH
PFH's Avatar
You're not supposed to use SR when the camera is mounted on a tripod.
10-17-2010, 04:28 AM   #4
Ex Finn.'s Avatar
Top LCD is showing full battery so that is not it.
SR should disable in bulb automatically. Could be a real problem requiring service.
10-17-2010, 04:09 PM   #5
Wheatfield's Avatar
You realize that is what the camera does during DFS, which I believe is always present in Bulb?
10-17-2010, 07:18 PM   #6
yes is does in Bulb and Remote mode
10-17-2010, 08:47 PM   #7
KansasHorizons.com's Avatar
Mine is doing that too, It always has. Its on tripod and bulb mode, it is during DFS.... I used to just turn the camera off and back on and of course the picture would finish processing but the noise went away but the other night that part started malfunctioning too, Now often you lose the picture if you shut it off.
One thing I know is that it seems it is getting louder all of the time....
I honestly thought it was holding the mirror up for some lame reason checking it shows it is not..
Also whatever it is can be physically felt.
10-19-2010, 09:09 AM   #8
I was hoping for some additional input from other users that are using bulb mode.....
10-19-2010, 10:59 AM   #9
That really sounds like a serious malfunction to me. I can't see any reason for the camera to do that. (unless you haven't asked for crazy amount of dust shaking)
10-19-2010, 11:04 AM   #10
Senior Moderator
Nass's Avatar
I use bulb a lot - never had anything like that though. Mind you I don't use SR with bulb either.
10-19-2010, 12:10 PM   #11
QuoteOriginally posted by Nass Quote
SR goes off automatically in bulb, the noise is assumed to be SR but would be inconsistent with the settings, It only comes on after the shot is taken.
To me its like a dry bearing fan trying to run on the left side internal of the camera (as shooting). Mine is not as loud as his but very noticeable when outside shooting in the quiet air.
camera, dslr, photography
k-7 SR malfunction pentaxmx Pentax DSLR Discussion 0 10-16-2010 09:34 AM
K200D malfunction cosmicap Pentax DSLR Discussion 6 06-08-2010 10:54 PM
K20D sensor malfunction tibi Pentax DSLR Discussion 17 09-09-2009 11:47 PM
Shutter Malfunction on k200 mtroute Pentax DSLR Discussion 7 07-15-2009 03:01 PM
Card malfunction Warblingostrich Pentax DSLR Discussion 2 01-22-2008 02:35 AM
All times are GMT -7. The time now is 07:53 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
