10-19-2010, 11:45 PM - 1 Like   #1
Pentax k-x - locked at ISO 400?
Hey gang, i tried searching for a full chart of how to change the minimum iso settings based on menu settings, but didnt find anything.
Im wondering why my camera has made ISO 400 made itself the minimum choice? It was ISO 200 but then i started messing around :P
Also, my high ISO pictures are really really grainy, what tools can fix this when shooting in RAW?
10-20-2010, 12:07 AM   #2
Two camera options can have an influence on the base ISO setting:
- Menu Capture 1 > D-range settings > Highlight Correction / Shadow Correction On/Off
- Menu C1 > 3: Expanded sensitivity > On/Off
Turn on expanded sensitivity, and turn off highlight correction and shadow correction, and you should see ISO 100-12800 as your ISO range.
10-20-2010, 12:28 AM   #3
Awsome. Will try it out. THANK YOU!
10-20-2010, 01:39 AM   #4
Also it can be relataed to set ISO mode: AUTO/FIXED
1 Press the four-way controller in Capture mode. The [Sensitivity] screen appears.
2 Use the four-way controller
to select [AUTO Setting] or [Fixed Value].
and
The sensitivity range can be expanded to a range of ISO 100 to 12800 when
[3. Expanded Sensitivity] in the [A Custom Setting 1] menu (p.81) is set to [On].
camera, dslr, iso, pentax k-x, photography, settings
People 400 ISO pushed to 1600 icywarm Post Your Photos! 3 07-16-2010 10:31 PM
Grainy shots with k-x at ISO 400 rwik78 Troubleshooting and Beginner Help 14 06-09-2010 10:52 AM
ISO locked on K-x? JONNY1981 Pentax DSLR Discussion 10 04-28-2010 06:49 AM
TAV max iso 400? denhamcla Pentax DSLR Discussion 5 08-27-2009 09:45 PM
K10 D is only good at 400 ISO Captain Pentax DSLR Discussion 21 07-22-2008 01:07 PM
All times are GMT -7. The time now is 05:30 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
