10-20-2010, 10:01 AM   #1
Startup procedure
I just received my wife's K-x and I would like to know what would be the best startup procedure. I know about the battery issue so I guess I should buy a set of Eneloop to begin with and fully charge them. Then, what about the firmware? When should I update it? Is there something else I should know in order to give it a good strat?
10-20-2010, 10:13 AM   #2
tomtor's Avatar
Check for firmware version
QuoteOriginally posted by SylBer Quote
I should start with checking the firmware version to see if any update is needed.
Turn the camera on with the menu button pressed:
Latest K-x Firmware Update : Software Downloads : PENTAX
If the version is 1.01 then all is well.
I used my camera a lot before the first firmware update arrived, if you're using Eneloops there is no real reason to update the camera, but it will not harm either...
10-20-2010, 10:56 AM   #3
jolepp's Avatar
About the only scenario where it might be broken would be if the ran out of power during the firmware update. To avoid this, putting in the provided lithium cells, waiting 30s, powering up to make sure that firmware in fact needs an update (*) and that the battery indicator is green (= cells good) and then going ahead with the update if needed would seem like a good way to start.
(*) Keep the menu-button pressed when turning the power on and you should get a screen stating the current firmware version.
10-20-2010, 11:50 AM   #4
Add to your checklist at a minimum a Sanyo brand eneloop charger as well as just the eneloop AA's. Regular NiMh chargers don't always know how to charge eneloops properly.
And I'd also download and install the firmware off the Pentax site even if the firmware indicated says 1.01 in-camera. There have been a series of 'silent' firmware updates by Pentax that haven't bumped up the major firmware number, but were updates nonetheless, so it might be useful to just grab what's on the site and install it anyhow.
It might also be useful to update the name information in the 'Copyright Information' section (Menu > Settings > 2: Copyright Information) to reflect your name.
I'd also run a series of clean ups (Menu > Settings > 4) like the Pixel Mapping, do a Dust Alert to see if there was any dust detected on the sensor, and run a cycle of Dust Removal shakes if necessary to clean the dust off, or do a full clean if necessary. Etc.
10-20-2010, 12:10 PM   #5
"Duraloop"
You are in Quebec, this weekend Pharmaprix has the 4xAA Duracell Precharge (Rebadged Eneloop) at 6.99. Make sure you take the ones with the white top. Like the one on the right.
10-20-2010, 05:18 PM   #6
Thank you all for the good advices. I guess I'll follow the prescribed procedure and go for a little photowalk. Merci pour la plug
camera, dslr, photography, procedure, startup
Contest Rules, Procedures, & How to Submit Adam Monthly Photo Contests 244 05-06-2017 07:30 PM
Pentax K-x first image capture on every startup comes out black akqrate Pentax DSLR Discussion 8 04-13-2010 11:50 PM
The Startup cost of Shooting Film little laker Pentax Film SLR Discussion 9 03-28-2010 11:22 AM
Need help with the contest procedure? Adam Site Suggestions and Help 0 02-19-2010 05:00 AM
K10D startup problem killernils Pentax DSLR Discussion 3 06-19-2009 01:53 AM
All times are GMT -7. The time now is 05:15 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
