09-13-2007, 05:49 PM   #1
pcarfan's Avatar
Firmware1.10 ISO setting by dial Question ?
The only update that interests me for now is the ability to control ISO with the dials. But, I don't want to do it by sacrificing the EV control. So, my question is, will I still be able to press the EV compensation button and use the front dial in Av mode to do exposure compensation? If YES, I presume the update allows the changing of the ISO by the front dial as it is rotated on it's own, adjusts EV when EV is pressed and adjust bracketing when bracket switch is pressd in? right?
The reason I ask is, the screenshot of the custom menu change shown with the firmware update seems to indicate I have to either choose the front dial for ISO or EV?
This link shows the screenshot (fourth one from the top) of the custom menu which seems to show a choice between ISO or EV for the dials.
PENTAX DIGITAL CAMERA INFORMATION PAPER
Thanks.
09-13-2007, 07:12 PM   #2
QuoteOriginally posted by pcarfan Quote
Thanks.
You can configure the front or back dial for av/ev/iso in the way that you want.
And if you press ev button and front dial you can change the ev and if you press ok and ther front dial you can change the ISO.
sorry if my english is no so good today,
Marcelo
09-13-2007, 07:52 PM   #3
pcarfan's Avatar
Thank you!, you've been very helpful.
09-14-2007, 03:51 PM   #4
Miserere's Avatar
Like mephiska said: If you set the front dial to be ISO, then just turning it will change the ISO. To change the EV you have to press the EV button on the back and turn the front dial.
I have found the upgrade very useful and now have the camera set so the empty dial in Tv and Av controls the ISO.
09-16-2007, 01:54 PM   #5
pcarfan's Avatar
QuoteOriginally posted by Miserere Quote
Thankyou for that clarification especially being your first post. So, the empty dial controls ISO even without the ok button, that would be very conveniant indeed. I will be upgrading soon.....
09-16-2007, 08:37 PM   #6
Miserere's Avatar
pcarfan, no OK button needed :-) But you do have to set this up in the Custom settings menu.
camera, compensation, control, custom, dslr, ev, front, iso, menu, photography, update
Problem with setting ISO on new White K-x whbroker Pentax DSLR Discussion 5 04-15-2010 10:03 AM
K-x high ISO setting? tokyoso Pentax DSLR Discussion 10 02-23-2010 11:34 AM
program a iso dial.... echospace Pentax Film SLR Discussion 3 07-30-2009 07:18 PM
Setting ISO 160 on analog dial? CSoars Pentax Film SLR Discussion 5 12-24-2008 03:28 PM
Does anybody know how to fix the ASA/ISO dial on a Super Program? pasipasi Pentax Film SLR Discussion 1 08-26-2008 03:01 PM
All times are GMT -7. The time now is 06:09 AM. | See also: NikonForums.com, part of our network of photo forums!
