10-30-2010, 10:07 AM   #16
inferno10's Avatar
You can always get a Wein Safe-Sync if you're unsure about the trigger voltage. It can handle up to 400V.
- Jason
10-30-2010, 10:14 AM   #17
Squier's Avatar
QuoteOriginally posted by JeffJS Quote
The Wein goes between the flash and the hot shoe. For your corded arrangement I would put it on the shoe, plug the cord on to the wein, then your flash on the other end of the cord. The Optical triggers, are fired from the flash light of your built in flash and make no physical connection to the camera.
Ah, i didnt realise that gadget was called a wein. I only see one mount on the wein gadget though, so thats not going to work, as there's nowhere to run the extension cable off
10-30-2010, 10:17 AM   #18
drougge's Avatar
Sounds to me like your meter likes to show lies when what you measure is outside the set range. The flash probably has a voltage >200V.
I would get another old flash, they're cheaper than protection gear (at least here in Sweden.)
10-30-2010, 10:21 AM   #19
QuoteOriginally posted by Squier Quote
You just mount it on the shoe.
Wein Safe Sync Hot Shoe to PC Sync Adapter Camera protection low voltage trigger
.. and then connect everything as you normally would. If you're handy with a soldering iron and some heat shrink tubing, there are probably dozens of ways to modify a cord to do the same thing, for pennies on the dollar.
10-30-2010, 10:34 AM   #20
Squier's Avatar
Wouldnt i just be better off finding a flash with safe voltage, like a 280t
10-30-2010, 10:40 AM   #21
Squier's Avatar
QuoteOriginally posted by drougge Quote
Yes i'm beginning to think i would rather go the simple route, and buy a flash that doent need all these saftey nets and triggers and other gadgets.
10-30-2010, 10:50 AM   #22
Yep..... And that flash has swivel and tilt (I'm not familiar with your Sunpak). You can even use it in auto mode probably with better results than a P-TTL unit. K200 is PTTL, Correct? If I remember correctly, the 280 was around 9 or 10 volts.
10-30-2010, 10:53 AM   #23
Squier's Avatar
I dont know the exact voltage Jeff, but its safe according to the botzilla list. It would certainly take the worry and extra gadgets out of the equation
10-30-2010, 10:58 AM   #24
I sold one a few months ago in the marketplace. Before selling a flash I always check and one thing I can state for certain, it's safe. I even tried it out for a few shots on my K7 which is still working fine.
10-30-2010, 11:01 AM   #25
Squier's Avatar
Well i'm now looking at flashes on Evilbay and cross checking them on the Botzilla list
10-30-2010, 11:17 AM   #26
I've got a couple of Nissin 360TW auto thyristor flashes I use with my K100D (and a PTTL Sigma EF-500 on the camera) ,they're 10v, and have a useful switchable fill flash in addition to the normal tilt/swivel 36 guide no. flash. And they're cheap, so definitely recommended! I use them with 2 optical hot shoe triggers with a light tent basically surrounded by light. Being only 10v, I have used a Nissin on my K100D hot shoe as well, before I got the Sigma, and they worked well, letting the flash sort out the exposure.
10-30-2010, 11:34 AM   #27
Squier's Avatar
Note Steve, cheers. No Nissins on Evilbay by that model number at the moment, it seems
10-30-2010, 01:35 PM   #28
Lowell Goudge's Avatar
What you have discovered is that cheap volt meters have an input resistance that changes with scale selected. Look on the meter and you should see the input resistance in ohms per volt of the scale selected. To really be sure of input voltage you should use a meter that has a constant input impedance of 20meg ohms or more
But with the measurements you have you should be able to plot the readings and project the maximum voltage
10-30-2010, 01:40 PM   #29
Squier's Avatar
I'm not that clever. I'm going to side with safety and simply buy one thats already on the ' safe ' list
camera, dslr, photography, test
12 volt battery charger for K7 battery stuskier Pentax DSLR Discussion 4 11-22-2009 10:16 AM
Flash Trigger Test Review--ISHOOT PT-04 CN pentax09 Flashes, Lighting, and Studio 7 10-14-2009 05:17 PM
1.5 volt silver-oxide battery dyusem Pentax Film SLR Discussion 11 03-12-2009 06:18 PM
How not to test your Cactus Wireless Flash Trigger xs400 Post Your Photos! 7 02-10-2009 07:01 AM
Interesting DR Test and BG Noise Test of the K20D RiceHigh Pentax DSLR Discussion 14 06-25-2008 09:49 AM
All times are GMT -7. The time now is 07:19 AM. | See also: NikonForums.com, part of our network of photo forums!
