10-30-2010, 06:28 AM   #1
Squier's Avatar
Trigger Volt test - which is right ?
I just tested a Sunpak 431 Auto. The Botzilla pages reckon :
" 30-50V, according to Marcus Bletz "
I used a Digi VM and on the DCV 2 setting got 0.34 ( +/- )
DCV 20 setting got 3.34 (+/-)
DCV 200 setting got 16.9 ( +/- )
Do these look right, do they look consistent, and also which is right ?
0.34v seems completely wrong, probably used wrong setting on DVM
3.33v seems too low - at least according to one guy on Botzilla
16.9v also seems too low.. according to etc etc
Should I test again ? DVM is working correctly by the way
10-30-2010, 07:17 AM   #2
2 volt limit is too small for testing a trigger voltage. At 20, if the Botzilla page is correct, should show OverLimit (OL) or something like that as should the 2 volt limit. It may even show that at DV 200 in some cases. However, 16 volts is a believable number if you tested it properly (and should have show with your meter range at 20 volts). All you should need to do is measure the voltage between the side contact on the shoe and the center contact on the bottom (do not trigger the flash for the measurement, just measure the static voltage).
Could also be that the flash is no good.
10-30-2010, 07:45 AM   #3
Squier's Avatar
Thanks Jeff, well i tested again just on the DCV 200 range, and got 15.7 , so almost consistent with previous DCV 200 test
But the flash has always needed firing, because otherwise, with the flash set to battery and ready to fire, DVM tips in place and making contact ( +pos on centre , - neg on side ) I dont get a reading.
Well i get a reading, but it it just states 1.
The figures in previous post were all obtained when actually firing the flash. The flash seems to be working ok
If the flash doesnt need to be fired, is there something else wrong ?
10-30-2010, 08:00 AM   #4
QuoteOriginally posted by Squier Quote
With a decent VM - or + doesn't matter put your VM to 200 DC and measure, if it is above 30V it can electrocute your digital camera according to Pentax. I wouldn't go higher than 20V though.
Response from Pentax-Support devision regarding Flash Trigge - Steve's Digicams Forums
10-30-2010, 08:09 AM   #5
Squier's Avatar
Thanks for that
Still not 100% sure though. The botzilla page mentions 30-50v for the Sunpak 431 Auto, but there's only one person on the list. So just one test only, i presume. At best i only got just over half the lowest of that trigger voltage
Also, if the flash doesnt need to fire for trigger voltage test, why didnt i get a reading till i fired the flash?
The switch on the rear can be set to either
1. OFF 2. AC HV ( high voltage ? ) 3. BATT
Presumably i need it switched on to the batt setting
10-30-2010, 08:15 AM   #6
Squier's Avatar
tested again on DCV200 , had to fire the flash though, and got an instant reading of 113v , very briefly
difficult to know whats going on here
10-30-2010, 08:20 AM   #7
chedoy's Avatar
So you are saying that the meter does not read a voltage unless the flash has just been fired? In that case, the hot shoe voltage will not be anywhere near its maximum value.
A lot of digital meters read 1 when the measured voltage is higher than the range set on the meter. In line with it not being able to measure when the flash is charge up, that would be consistent with the voltage being way up there. My old SunPaks are over 200 volts, but designs differ,
As far as measuring .34 to 16 volts, I don't know why yours is so erratic, except I know that cheap meters load down the flash and make the voltage read far lower than its actual value.
Bottom line, if you're assuming your camera can tolerate 20 volts, Botzilla says 30-50 volts, and you're getting nonreproducible numbers, maybe hold off on using that sunpak.
10-30-2010, 08:21 AM   #8
Jodokast96's Avatar
I think it's pretty safe to say this. It's not worth the chance at this point to put that thing on your hot shoe without something like a SafeSync. Get one of those or a cheap optical trigger and use it off camera.
10-30-2010, 08:35 AM   #9
Sounds like your flash is going to ebay or to a friend who still uses old Praktica-like film cameras. I do measure flash'es from contacts when only they are filled and ready light is on , one VM probe goes to + on VM other to ground, try flash contacts 2 by 2, the highest you get is the actual trigger voltage. The reason is, you don't want 110V on your camera's contacts when flash is ready.
10-30-2010, 08:38 AM   #10
Squier's Avatar
Chedoy - yes, on DCV200 with flash unit ready to fire, i simply get a reading of 1. Only got readings after firing
I think you guys are right. I'm not going to risk this on my K200
10-30-2010, 08:38 AM   #11
Any flash I've ever tested did not need to be fired to test the voltage. Remember here that there is actually no load on the flash until the flash is commanded to fire by the camera (so there is no current flow). When the flash fires, the voltage goes to 0 (you need a meter with a memory to actually see this happen, mine is a Fluke 87.
Either way, if you saw a voltage of 100+, I would save it for a triggered flash in a strobist setup and keep it away from the camera (unless you put a protector on the shoe to limit the voltage the camera sees). Even at 30-50 I don't think I would risk it. I agree, probably 20 volts maximum.
10-30-2010, 08:42 AM   #12
Squier's Avatar
Jeff, the flash was mainly for offboard use in macro, with a curly hot shoe extension cable ( not a sync cable ) , but i would want to use the flash direct on the shoe too, so i'm better off not taking any risks, as advised
10-30-2010, 08:49 AM   #13
You can use your flash with optic slave adapters, this is the only way, other than Wein safe-syncs
I've purchased coupla of these but never used it.
Camera Flash Hot Shoe Sync Adapter Slave Trigger - eBay (item 220677640820 end time Nov-01-10 12:58:03 PDT)
10-30-2010, 09:36 AM   #14
Squier's Avatar
They look interesting - but being new to flash, its confusing
I cant see where this little gadget fits in, if using a hot shoe flash extension cable with flash unit mounted on a bracket
10-30-2010, 10:07 AM   #15
The Wein goes between the flash and the hot shoe. For your corded arrangement I would put it on the shoe, plug the cord on to the wein, then your flash on the other end of the cord. The Optical triggers, are fired from the flash light of your built in flash and make no physical connection to the camera.
camera, dslr, photography, test
12 volt battery charger for K7 battery stuskier Pentax DSLR Discussion 4 11-22-2009 10:16 AM
Flash Trigger Test Review--ISHOOT PT-04 CN pentax09 Flashes, Lighting, and Studio 7 10-14-2009 05:17 PM
1.5 volt silver-oxide battery dyusem Pentax Film SLR Discussion 11 03-12-2009 06:18 PM
How not to test your Cactus Wireless Flash Trigger xs400 Post Your Photos! 7 02-10-2009 07:01 AM
Interesting DR Test and BG Noise Test of the K20D RiceHigh Pentax DSLR Discussion 14 06-25-2008 09:49 AM
All times are GMT -7. The time now is 06:52 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
