10-30-2010, 02:53 PM   #1
K200 blurry & not adjustable
Hi, I'm new to dslr but i recently found a k200 for sale for 300 and i thought it was a great deal but when i tested the camera out everything was blurry in the view finder no matter how much i adjusted the lens. even the red lights at the bottom when you look into it were blurry...but when i took a picture and viewed it on the screen it wasn't blurry at all. i didn't buy the camera because i wasn't sure if i would be able to fix the problem. would it be something to do with the lens or would something have to be replaced in the camera itself? i appreciate any help on this or thoughts on wether its still worth getting!! thanks !
10-30-2010, 04:11 PM   #2
Did you try adjusting the diopter on the viewfinder?
That is what is sounds like to me.
10-30-2010, 04:20 PM   #3
Sounds like the dioptre. It's easy to adjust and in about 2 seconds your problem will be solved, I think. The manual describes what to do.
In case you didn't get a manual with your purchase, here's a PDF version of the K200D manual:
http://www.pentax.jp/english/support/man-pdf/k200d.pdf
10-30-2010, 05:28 PM   #4
that actually sounds about right. thanks so much for your speedy replies! i'll check it out tomorrow and see if that fixes the problem and i'll let you know. again thanks so much!
camera, dslr, k200, lens, photography
Super-Tak 200mm/4: too many adjustable rings, who can help? Rense Pentax SLR Lens Discussion 3 07-30-2009 09:54 AM
K20 & K200 listed @ B&H heatherslightbox Pentax News and Rumors 0 01-27-2008 08:05 PM
1st of many ?'s (Pentax 1:2 50mm & blurry photos) lapeen Pentax SLR Lens Discussion 15 08-24-2007 06:48 PM
All times are GMT -7. The time now is 06:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
