11-01-2010, 07:00 AM   #1
Squier's Avatar
X-sync cable v. Hotshoe extension cable
When using flash offboard, is there a difference when using the x-sync / PC socket cable or hotshoe extension cable ? Or would you use both ?
Any advantages or disadvantages ?
11-01-2010, 07:33 AM   #2
alohadave's Avatar
The PC/Sync port is a simple trigger and there is no communication between the camera and flash other that to tell the flash to fire.
With a hot shoe cord, you can do P-TTL (with a compatible flash) or simple triggering, depending on the cord you use.
11-01-2010, 08:25 AM   #3
Squier's Avatar
Thanks - i dont have a P-TTL flash unit, just an old style type, so presumably, a non P-TTL hotshoe ext cable will do ?
11-01-2010, 08:30 AM   #4
Bobe416's Avatar
If you are going to be shooting manual flash, you might want to look into the Cactus v4 radio triggers. So far they work great with my K10D
11-01-2010, 08:42 AM   #5
Squier's Avatar
Why a radio trigger ? Is there some advantage over simply pressing the shutter button to fire the flash ? Presumably the onboard flash has to be raised too
11-01-2010, 08:54 AM   #6
alohadave's Avatar
QuoteOriginally posted by Squier Quote
Radio triggers go in your hot shoe (or PC/Sync port depending on the model) and trigger the flash with a receiver. It means that you can go cordless. You can also trigger more than one flash at a time.
You don't use the onboard flash unless you are using flashes with optical sensors.
11-01-2010, 09:03 AM   #7
Squier's Avatar
Ah, thanks. I dont mind cables, as i'm not bothered by them.
Is an Auto Thyristor one of those old flash units with optical sensor ?
11-01-2010, 10:07 AM   #8
alohadave's Avatar
It is, but not in the way you are thinking. What you are looking for is an optical trigger or optical slave (the terminology varies).
An Auto Thyristor is used by the flash to determine when the flash has put out enough light based on how it is set.
11-01-2010, 10:16 AM   #9
Squier's Avatar
Doesnt sound too bad
I'm happy enough with firing the flash from the shutter button, so i'll not go for triggers if all they do is save buying one hotshoe cable
11-01-2010, 10:28 AM   #10
Depending on how old the flash is, this might be a nasty way to fry your camera. Quite a few of the older flashes have trigger voltages in excess of what the camera can handle. I don't think that this is a problem with the X-sync port (somebody please confirm this), but it can be a problem with the hotshoe.
11-01-2010, 10:34 AM   #11
Squier's Avatar
I checked the voltage at botzilla and its fine
cable, camera, dslr, extension, hotshoe, photography, x-sync
Flash Extension Cable tomcochrane Troubleshooting and Beginner Help 2 10-10-2010 02:57 PM
For Sale - Sold: Pentax AF540FGZ flash, off-camera sync cable (US/CAN) JasonA Sold Items 1 04-06-2010 09:17 PM
Two flashes and one hotshoe...sync cable question... PentaxPZ Flashes, Lighting, and Studio 6 09-15-2009 02:03 PM
All times are GMT -7. The time now is 12:18 AM. | See also: NikonForums.com, part of our network of photo forums!
