Originally posted by Corvairfan
If I understand it correctly, as of now I have formatted it in the camera and when I put it in my card reader I see the DCIM folder. I know NOT to put the update in there but just drag it onto the card. So when I look at the card on my computer I see the update and the DCIM folder side by side. Right?
Don't worry about that, the camera will know what a DCIM
folder is, and the difference between a folder and a file in the rootdir of the media.
The firmware update file needs to be in the expected format, and filename convention~sequence, too; ie. not packaged in an archive or weirdo renamed for 'human readable' convenience.
RTFM anyway.
Quote: Or am I supposed to use the computer to format the card so it is completely empty?
You could, but make sure you format it with the right filesystem that the camera will accept and be able to read from.
That will be FAT or FAT32,
not exFAT and definitely not NTFS. In-Camera disk operating systems just aren't that sophisticated.
IOW; use the camera to do the format job instead and you don't have to know anything about the latter. The vendors expect and package these updates and write the camera's OS accordingly to cater for non-computer literate users.
The KISS principle applies and reading between lines isn't required and can (often does) only lead to serious problems.
Did the instructions specifically state that it must be formatted
in a computer? They will if it need be. Trust me.
.R.
