11-06-2010, 09:01 PM   #1
How does my camera always have the right date/time?
This is something I've been wondering about for a while now, how does my GX-10 always know what time it is, even though I've never set the time on its had the battery in and out of it? Not really important, I'm just curious.
11-06-2010, 09:03 PM   #2
I'm pretty sure there's an internal backup battery- most modern devices have one!
11-06-2010, 09:24 PM   #3
If you've ever assembled/taken apart a computer, it is analogous to the CMOS battery on a motherboard. It is a small (usually lithium) battery, independent of the main power supply, that provides constant power to maintain the system time and BIOS settings even when the computer is completely disconnected from power. The internal battery of the camera (and many high tech electronics) is the same concept.
Eventually it will die, and require replacement (easy for computers, not so easy for self contained electronics), but for most consumer electronics, the device will itself be replaced long before that happens because the power drain is so small (10+ years).
11-06-2010, 09:53 PM   #4
sterretje's Avatar
I doubt it's a battery. My feel is that it is a super capacitor.
It is charged when the 'normal' battery is in the camera. If your camera is left without a battery for a long time, it will eventually forget the time (similar to a battery that runs flat). Put your 'normal' battery back in, set the time, and it's good for a long time again.
11-06-2010, 09:57 PM   #5
KungPOW's Avatar
Its a bug. They will solve it whn they release the K-3
11-06-2010, 11:26 PM   #6
pentax user's Avatar
there were a few times my k200d forgot the time and date after not using it for months. I don't really know how this work.
Try not using it months and leave the battery out, i will eventually reset the time
11-06-2010, 11:51 PM   #7
QuoteOriginally posted by pentax user Quote
If this is the case, then as Sterretje said, it's probably a ("super")capacitor. Capacitors store much less energy than a battery, and rapidly self discharge, so they will lose charge much sooner, but can be "recharged" an effectively unlimited number of times.
Devices that use battery powered RTCs will never "forget" until the battery dies (or is manually reset), after which it will be unable to remember at all until the battery is replaced (cannot be recharged).
11-07-2010, 12:07 AM   #8
I'm quite sure it's a capacitor instead of a battery. Hint: if it were a battery, the manual would mention it - how to change it when necessary.
IIRC the *istD had a battery.
11-07-2010, 12:09 AM   #9
jolepp's Avatar
Most likely a capacitor combined with minuscule power consumption of the real time clock.
11-07-2010, 08:05 AM   #10
raz
My K100D loses the time when it doesn't have the batteries in it for a while.
11-07-2010, 08:16 AM   #11
My K200D would lose its date and time when stored without a battery.
camera, dslr, photography, time
help! pentax K-M requires adjust date time all time carl zeiss Pentax DSLR Discussion 9 10-05-2012 07:27 PM
Date & Time Issue ladyteri934 Troubleshooting and Beginner Help 8 11-04-2010 04:04 AM
Lossing time and date fanfaron Pentax DSLR Discussion 8 09-30-2010 01:38 AM
Date/Time Stamping Pictures sparetyme Troubleshooting and Beginner Help 5 03-05-2009 11:34 AM
Date, Time, and Location? markpsf Pentax News and Rumors 2 01-23-2008 02:59 PM
All times are GMT -7. The time now is 11:41 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
