11-11-2010, 01:53 PM   #16
Dubesor's Avatar
And you do have the "enable aperture ring" option enabled, right?
No such setting on the *ist D, but there is "F stop other than A" which is already On
11-11-2010, 02:11 PM   #17
Lowell Goudge's Avatar
I don't know what to suggest next except that there is either an issue with the lens stuck wide open or the camera body not working
Does the aperture close when you turn the aperture ring and the lens is not on the camera
Also check if the aperture lever is not hitting something, perhaps the shield around the activation lever
11-11-2010, 02:46 PM   #18
Dubesor's Avatar
Yes, that works fine. And like I mentioned, I also tried other M lenses to make sure it wasn't this particular one that was causing issues.
Will do ...
11-11-2010, 08:19 PM   #19
Is it m lenses or all manual aperture lenses. What about an A lens out of A
*ist, button, camera, dslr, lenses, photography, settings, shutter, stop-down
K-x Stop-down metering with m-42 lenses Bazwell Pentax DSLR Discussion 8 11-20-2009 12:57 PM
Ist D L new lithum battery = no power on meter oilfield trash Photographic Technique 4 11-08-2008 09:21 AM
Meter older lenses on the *ist? Vertex Ninja Pentax Film SLR Discussion 11 07-26-2007 04:37 PM
Can I use smc Pentax-A lenses on my *ist D/*ist DS? Ole Pentax DSLR and Camera Articles 3 05-18-2007 10:23 PM
All times are GMT -7. The time now is 08:46 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
