09-19-2007, 01:57 PM   #1
HowLowCanYaGo's Avatar
SMC-M 50mm 1.7 problems
Hi,
I just received my "M" series 50mm 1.7 in the mail. Unfortunately, when I place it on the camera I get the flashing "F--" on the LCD. I understand this is what happens because the camera doesn't read the aperture mechanically...is there a way to set the lens to automatic? I don't see an "A" setting anywhere on the aperture ring, yet I know for sure that this lens is compatible with digital format...
What am I overlooking?
09-19-2007, 02:27 PM   #2
No, the M series did not have an auto setting. It does not have any electrical contacts. You need to go into the custom function menu and allow lens in setting other than A.
09-19-2007, 02:30 PM   #3
On my istDS with that lens, I had to go into the Menu - Custom Settings - Using Aperture Ring - (Option2) Permitted. This makes it so that (to quote the camera itself) "Pictures can be taken even when the aperture ring position is other than A". This is necessary because that lens does not have a position 'A'.
Hope this helps on the K10D!
09-19-2007, 04:50 PM   #4
pschlute's Avatar
You set exposure in manual mode by setting the aperture on the lens , then press the green button. The camera will stop down and meter, then assign a shutter speed automatically. Take your picture.
You can use the lens in Av mode....however the lens will always be at maximum wide aperture no matter where you have set the the f stop on the lens.
09-20-2007, 10:47 PM   #5
I have three manual lenses and though I'm still "playing" with them to see what works best with the K10, so far Manual mode rules the roost.
Change the menu settings as instructed above, switch to M mode and adjust your aperture/speed just like you do with the old film cameras. Takes a bit getting used to but after a while, you might just start finding you like all manual better for the really important shots
09-21-2007, 10:57 AM   #6
pschlute's Avatar
Frogroast
Forgive me if you know this already, but you can also use the following method.
In manual exposure mode turn the DOF preview lever so the lens stops down. You will see that the meter is still visible and you can turn the aperture ring (or the shutter speed dial if you are really dextrous) until you get the light meter reading centred. Then release the DOF lever, focus and press the shutter.
Oh......... its like using my old MX again !
09-21-2007, 04:49 PM   #7
Frogroast
Are you using Digital Preview method?
09-23-2007, 03:07 PM   #8
pschlute's Avatar
QuoteOriginally posted by ddhytz Quote
No. I always use optical preview. I dont think the metering method I outlined above will work if you have the camera set to digital preview.
btw I cannot see the point of digital preview at all. It is harder to check the DOF on the screen compared with looking through the lens. If you do want to check the picture as captured....what is wrong with pressing the shutter release ? You can delete the picture if it doesnt satisfy you.
No..I dont get "digital preview" at all.
50mm, aperture, camera, dslr, lens, photography, smc-m 50mm
For Sale - Sold: SMC 85mm f/2.2 Soft, SMC-M 50mm f/4 Macro, SMC-M 135 3.5, SMC-M 85mm 2, SMC-M jgmankos Sold Items 3 06-14-2010 06:48 PM
For Sale - Sold: K-mount Tamron-F 2x Pz-AF BBAR MC7 TC, TWO 50mm SMC-M F1.4, and a 50mm SMC-A F pxpaulx Sold Items 11 06-14-2010 07:42 AM
Problems with SMC Pentax-F 35-135mm F3.5-4.5 Darius4522 Pentax SLR Lens Discussion 8 11-26-2009 05:31 PM
For Sale - Sold: SMC 50mm, SMC 50mm, Tokina RMC 28mm bri_n_m Sold Items 3 06-20-2009 12:27 AM
problems with 50mm 1.7 M, mayoapo Pentax SLR Lens Discussion 16 05-22-2007 04:20 AM
All times are GMT -7. The time now is 05:31 PM. | See also: NikonForums.com, part of our network of photo forums!
