This has been a much discussed "issue" with the difficulty to remove the SD card out of the K7 (and the K5 seemingly).
Ed:
I own the K7 and I found it hard to remove during the first few weeks.
This seems much better now, after having put in/removed the card coountless of times.
As far as I am concerned, it is not a "problem" perse, rather an annoyance which usually goes away after a while.
The K5 also suffers from the same condition, so to speak, but it has not been a major subject of concern.
Here are a few links to that specific issue:
https://www.pentaxforums.com/forums/pentax-dslr-discussion/116238-secure-digi...d-slot-k5.html https://www.pentaxforums.com/forums/pentax-dslr-discussion/120285-problems-re...-my-k-5-a.html https://www.pentaxforums.com/forums/do-yourself/102523-how-make-easier-access...card-slot.html
I would recommend that you use the search engine provided herein on this forum when you want to post a new thread, that way, you may well find your answers faster and in more details.
Cheers.
JP
Reason: added links to the page
