09-20-2007, 08:02 AM   #1
k100d buitlin flash
Hi All,
i have firmware 1.02. seems that the k100d has no wireless trigger capabilities with the built in flash? do correct me..
i would upgrade if i had the moolah. but i am a bit short on that..
please help..
cheers!
Paeng
09-21-2007, 11:50 AM   #2
No, you're correct. I've got a Sigma EF-500 DG Super, which is the cheapest most powerful flash with high speed sync, and if I bought another one I could use one on the hot shoe to trigger the other using P-TTL to get the exposure right.
However, I can use the pop-up camera flash to light the subject with my external Sigma triggered from it, but only in manual mode, i.e. you have to dial in a power setting on the Sigma, but it does give a little help in working out the usable distance for each power setting in the form of a bar graph on the LCD., so for a static studio sort of setup it's actually usable for a bit of side fill.
09-21-2007, 11:57 AM   #3
and
You can get an off camera p-tt cable, or you can get some cheap cactus v2 wireless triggers off ebay. although that wil mean manual flash, which btw is not really that hard.
camera, dslr, flash, k100d, photography
Flash for K100D Frosty Pentax DSLR Discussion 10 04-29-2010 01:36 PM
Slow flash - fill in flash - k100d soalle Pentax DSLR Discussion 4 06-21-2008 02:06 PM
Flash for the K100D Blu Flashes, Lighting, and Studio 5 10-13-2007 12:49 PM
Can I use this flash with my K100D? Alvin Flashes, Lighting, and Studio 5 03-07-2007 05:01 PM
flash for K100D: what should I look for? WMBP Flashes, Lighting, and Studio 8 03-01-2007 03:20 AM
All times are GMT -7. The time now is 04:39 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
