Originally posted by Cam Traviss Hi Folks:
I remember this was discussed before on another forum, but I can't find it.
I want to change the numeric sequence on my images so that my K10 D will reflect a more accurate shot count. I got it today and shot with a card, and my shots are in the 100-0650 range. It really should be picking up the count at about 0050 or so. It had something to do with renaming a part of the SD card image number but I forget how. anybody remember?
Thanks very much
Cam Traviss
You might give this a try:
1. delete all but one photos on the card, and rename the only left one to IMGP0050.jpg (on a PC through a card reader).
2. go to Set-up Menu, set the
File # to Reset.
3. put in the card and take a shot. play back and check the file number.
4. if it's like what you want, then reset the
File # to SerialNo.
If this doesn't work, the best bet is to format the card, then do the above 2 to 4, you'll have a
brand new camera (file number starts from 0001)
