Originally posted by Silverkarn Well, i figured that if i need too i could line the bottom of the wood chest with rice, and then put something like a drying rack in the bottom so that the camera and such is sitting above the rice. With the heat from the bulb things would dry out pretty quickly.
I ask because my house is VERY dusty, and having two dogs doesn't help so i cant really leave my camera sitting out. I need a place to store it, but the place needs to be dry. And my wood chest that i made back in high school is still bone dry.
Faced with similar problem I recently picked up one of this style hard resin case with cut-cubed foam inside. They seem the best for looking after expensive camera gear, very strong, travel-worthy, fully o-ring sealed, water proof (almost), pad-lockable, and pressurised too (have a release valve fitted at the front).
Designed to keep the gear dry and fungus free.
Amazon.com: Resin case cubed foam: Electronics
I picked mine up in the tools section of a handyman/hardware chainstore, does the job and not expensive for fairly large size one too (even fit my 10" Netbook in it) compared to rich prices of the genuine camera stores ones such as Pelikan or HPRC brand.
Like you I have the dusty and moist/cold/hot household and seasons to contend with, so figured the small outlay was more than worth it for the value of my electronics camera goodies.
This Silica stuff can be handy and cheap enough to toss a couple of pkts in too, although your rice idea might be OK I suppose;
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Delectronics&field-...cant&x=16&y=17
.R.
