11-13-2010, 08:07 AM   #1
paperbag846's Avatar
Good replacement k20d focusing screen?
OK well I went and mucked up my focusing screen good (long story short: lens was on, camera recievd a jolt due to uncooperative flash, focusing screen tray unhinged, tried to take off lens, left a nice scratch on the screen, lens is ok).
Anyhow I'm a real nub and soaked the screen in some lens cleaner to try and remove some of the black rubber ground into the screen - now the thing is foggy AND scratched .
Well anyways I feel this is a good a reason as any to try out a new focusing screen. I have a good number of manual focus lenses so I have considered a split prism / microprism design. My major concern is metering - I would rather buy another stock screen if it will ensure the best metering. I have read so many conflicting reports on the metering with different aftermarket screens, so I'm asking you, the good people.
Right now I am thinking either the stock screen (LL-80) or a Jinfinance split prism (which I believe is a k1000 OEM blank, modified).
PS - I can't afford a Katz Eye.
11-13-2010, 01:16 PM   #2
FHPhotographer's Avatar
paper... I've used KatzEye on a K100 and K20 and they work. You do get what you pay for, but then I don't pay for the Optibrite or additional grid lines, so the base price of the KE quality and service balances the lower cost of other products for me. As for the metering, I've had the split collar on fast and slow DA, FA and Tamron lenses (from f1/7 to f/4) and never had a problem and never seen a metering accuracy drop-off from the OE screens.
11-13-2010, 01:42 PM   #3
QuoteOriginally posted by paperbag846 Quote
On my K10D I tried both of your proposed screens. Didn't like either of them and finally settled on the focusingscreen.com (K3) screen which I like very much.
Please note that theoretically any change in focusing screen will affect metering - even Katz Eye (they tell you this themselves).
11-13-2010, 02:24 PM   #4
QuoteOriginally posted by stevewig Quote
What didn't you like about the Jinfinance?
11-13-2010, 02:59 PM   #5
I have tried both the travor (which is like the Jinfinance screen) and the focusingscreen.com (k3) screen. I thought the k3 screen was brighter and clearer. I did not see any issues with metering other than spot metering.
11-13-2010, 03:06 PM   #6
QuoteOriginally posted by rockmaster1964 Quote
spot metering
So the K3 is a better screen because it is clearer and brighter, but both will meter equally well? I don't expect spot metering to survive this operation, but I also suspect that I will get a lot more keepers with the microprism.
Did you find the K3 a better screen for FOCUSING with? I.e., was it easier to identify accurate focus, etc.?
11-15-2010, 09:49 AM   #7
opfor's Avatar
I tried a couple of screens and in the end I had the best luck with one from a K-10. Your results may vary...
11-15-2010, 11:06 AM   #8
Both screens metered the same. I did find it easier to focus with the K3 screen.
11-18-2010, 09:26 PM   #9
v5planet's Avatar
Dumb newbie question: why should metering be affected by the viewfinder screen at all? Is the meter located beyond it?
11-18-2010, 09:45 PM   #10
The focus screen latch should stay in place even with a very hard blow! Have you ever taken the screen out before?...
1. If yes then when you push it up make sure its latched and then push slightly on the latch to make sure its tight.
2. If no, then its was not put on properly at the factory. Do make sure its secure now.
Not MF a lot I prefer the standard stock screen. I did the the screen the rule of thirds grid but found the stock (original equipment of K20D) to be best of what Pentax offers.
11-19-2010, 12:41 PM   #11
QuoteOriginally posted by v5planet Quote
Yes. The light sensor is in the "hump" of the camera, behind the focusing screen. This is why you need to cover the viewfinder (with your head or other thing) to prevent stray light from entering through the viewfinder and fooling the light sensor.
Back to the focusing screen for K20D, any screen with split image will render spot metering useless. Matrix metering is also affected, but not by much.
If you're not married to screen with split image, the best replacement screen for K20D and K10D, IME, is the LL-60 screen (for the ancient *ist series). This screen allows accurate metering with all lenses. LL-60 is difficult to find, however.
It is well known that the stock screen of the K10D and the K20D does not meter correctly in stop-down mode (necessary when you use M- or M42- lenses).
Linky
11-19-2010, 01:57 PM   #12
Ash
Community Manager
Ash's Avatar
I'll second the LL-60, being more attuned to composing images using the rule of thirds and not as 'busy' as the LL-80. I've had no problems metering with the LL-60 both in A and M lenses.
11-20-2010, 03:39 PM   #13
GeneV's Avatar
I've had no metering issues with the Jinfinance and the split screen is great for manual lenses or precise focus on an AF lens. Some of the others I tried--Travor was one of them--required shimming, and that was too much trouble. I haven't tried the K3.
11-20-2010, 06:01 PM - 1 Like   #14
Lowell Goudge's Avatar
I have a jinfinance single split in my K10 and a dual split in my *istD. These are good screens if you want a split image, but anyone like me, as a result also has the original screens I have an LL80 from the K10 and an LL60 from the *istD. Maybe someone will donate their old screen
camera, dslr, lens, photography, prism, screen, split, stock
Focusing manual lens with OEM focusing screen, is a split screen really needed? skid2964 Pentax Camera and Field Accessories 16 09-17-2010 02:54 PM
Focusing Screen for K20D Vasyl Pentax Camera and Field Accessories 14 09-07-2010 03:52 PM
ME Super Focusing Screen Replacement. Gashog Pentax Film SLR Discussion 6 04-29-2010 02:05 PM
For Sale - Sold: Pentax Brand Focusing Screens and Katz Eye Focusing Screen K10D/K20D (Worldwid superbass Sold Items 8 03-26-2010 01:42 PM
Li-80 K20D Focusing Screen? Blue Pentax Camera and Field Accessories 3 06-22-2009 06:07 PM
All times are GMT -7. The time now is 02:46 PM. | See also: NikonForums.com, part of our network of photo forums!
