09-21-2007, 05:58 PM   #1
How to measure battery life on the K10D
I have two batteries, one in the camera and one in the battery grip; I've set the priority to the grip battery, but how does one measure when the battery is about to go? I tried to use only the grip battery by removing the battery in the camera, but that wouldn't work.(What I meant there was that I wondered if the grip battery alone would power the camera; found out that it wouldn't, which surprised me.) I realize that the battery icon will appear 'washed' out when it is about to go, but I need something more definitive than that. Any ideas?
Thanks,
FLASH
09-21-2007, 10:01 PM   #2
stewart_photo's Avatar
QuoteOriginally posted by FLASH Quote
(snip) I wondered if the grip battery alone would power the camera; found out that it wouldn't, which surprised me. (snip)
Well, that certainly surprises me as well since I've been running my camera since almost the first day with only a battery in the grip. I talked to others here who are doing the same. And, as far as I know, there are no unique versions of the K10D. Therefore, unless you've selected something in the battery priority or other settings that would require the camera battery, your K10D should run solely off the battery in the grip.
stewart
battery, camera, dslr, grip, measure, photography
AA battery life jslifoaw Pentax DSLR Discussion 54 06-05-2011 05:26 PM
K10D Battery Life in "StandBy" Venturi Pentax DSLR Discussion 5 04-28-2008 05:38 PM
battery life m.orp Pentax DSLR Discussion 1 04-21-2008 08:10 PM
K100D battery life wildherre Pentax DSLR Discussion 23 12-12-2007 11:58 PM
Battery Life Jimsi777 Pentax DSLR Discussion 20 09-16-2007 07:03 AM
All times are GMT -7. The time now is 09:52 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
