11-15-2010, 07:11 AM   #1
retroflex's Avatar
K-x auto mode question
Can you set up the auto mode on a K-x to always use auto ISO and auto focus with shutter button? Normally I'd like to control ISO and AF myself, but when I hand over the camera to someone else I'd like as much automation as possible...
11-15-2010, 07:27 AM   #2
jolepp's Avatar
I guess not. Even in green mode the ISO stays in manual if set that way when turning the mode wheel (a misfeature IMHO). Also, the AF/MF switch mechanically disconnects the AF motor from the lens.
11-15-2010, 07:41 AM   #3
retroflex's Avatar
Thanks jolepp! When I said AF though, I didn't mean the AF/MF switch but that I'd like to AF using the ok button. And then override this to the shutter button in auto mode. I guess then this isn't possible either though.
11-15-2010, 08:03 AM   #4
jolepp's Avatar
There would seem to be no way to do that either I'm afraid.
11-15-2010, 09:43 AM   #5
Hypocorism's Avatar
QuoteOriginally posted by retroflex Quote
To the best of my knowledge you cannot AF with the OK button in any mode, the only usable alternate button for AF (except for the shutter button) is the AF/AE-L button - and then only when it's configured to its default of option 1 >> Enable AF1 at C.2.10 in the menu
An to address your O.P question;
By definition and default action (which you can't change), "Auto" Pict mode is just that, it "fully auto" controls ISO, shutter speed, aperture, the lot.
And yes, you then AF with a half depression of the shutter button, or, with the AF/AE-1 button as above.
.R.
11-16-2010, 01:27 AM   #6
retroflex's Avatar
QuoteOriginally posted by Hypocorism Quote
Thanks for the clarification! I was using ok button on my old DS and figured the K-x would work the same. However AF/AE-L button seems to be better positioned for this purpose.
.R.
Sounds logical, but it seems that's not the way it works. As jolepp said, if you set ISO 200 and then switch to Auto Pict, it will stay locked on ISO 200. Sounds like a bug to me.
I searched PF some more and found a workaround for this. If you set to not remember sensitivity when powered off, it will revert to auto ISO when powered on again. Since I always set ISO manually before starting to shoot, this will work both for me and others using it (who want full auto).
11-16-2010, 02:04 AM   #7
Hypocorism's Avatar
Hey you're both right there. I've never watched that Auto Pict behaviour closely before.
In fact, to me it seems to behave more "auto" in Program mode regarding its ISO setting and the automatic variance of it, depending of what light~dark scene you point the camera at, and tap the [re]focus button.
I'll play with the workaround and see if that makes sense to use, or has consequences.
.R.
11-18-2010, 06:47 AM   #8
retroflex's Avatar
Follow up to this... I played around with it some more now and found this to be the best compromise to use the K-x for both me and others not interested in messing with the settings...
- Turned off memory for ISO and exposure compensation.
- Changed SCN mode to "Kids" and tell my GF and others to use SCN mode. This seems to work much better than the "Auto Pict" mode, which more or less switches randomly between different modes. The kids mode seems to use a pretty quick shutter time along with a medium aperture and raises the flash if needed. Works good for indoors snapshots, haven't tried it outdoors yet, but I guess it should work in most situations.
- When I use the camera I use Av or M and set up ISO first.
auto, camera, dslr, iso, k-x, mode, photography
Slave 2 Mode x Auto Power Off BBear Pentax Camera and Field Accessories 15 07-14-2010 01:58 PM
Auto Focus mode/type in K-x thanglian Troubleshooting and Beginner Help 3 03-26-2010 10:48 AM
Auto vs P mode? maxmagnum Troubleshooting and Beginner Help 11 01-02-2010 08:40 AM
K100D Auto Bracket Mode dbuffington Pentax DSLR Discussion 1 09-30-2009 06:24 AM
auto ISO in M mode? not option? Akcelik Pentax DSLR Discussion 4 03-07-2007 05:38 PM
All times are GMT -7. The time now is 07:06 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
