11-16-2010, 01:03 AM   #1
K7 flash issue
Ive got a k7 and a YN 560 flash
the flash fires fine, adn recycled fine,
but on the second shot, the flash doesnt fire,
but the YN 560 beeps and recycles meaning it was supposed to be fired,
i thought it was just the battery so i switched to a new set of eneloops,
the problem is still there..
it really did get me into much hassle because I missed a dozen of shots because of this issue..
11-16-2010, 01:30 AM   #2
hoanpham's Avatar
Have you tried in manual mode only? seems like your YN560 is defect. did it fire on 3rd shot?
Set YN560 to manual mode, camera to manual mode 1/125 sec, flash to 1/4 power, then try.
I havent YN560, but it should be manual only flash. Also try to 'reset' the K7 by switching off/on.
11-16-2010, 01:45 AM   #3
QuoteOriginally posted by hoanpham Quote
tried it the problem is still there..
and yes the flash fired at the 3rd shot..
then doesnt fire at the 4th
then fires again at the 5th
11-16-2010, 05:08 AM   #4
hoanpham's Avatar
wait long enough to recycle the flash, like 15 seconds to be sure? connected directly to the hotshoe on camera? can you confirm the power setting on the flash? did it reduce the amount of light accordingly to the setting? try to set the power to 1/16 then 1/32 to check if it fires continuously.
11-17-2010, 10:19 PM   #5
flash set at 1/32 the problem is still there.
11-19-2010, 01:20 AM   #6
Pentaxor's Avatar
solution: buy a Metz (if you got the budget)
buy a Promaster (if you are in a budget)
11-19-2010, 01:52 AM   #7
hoanpham's Avatar
QuoteOriginally posted by redeleon Quote
You still not confirm the output power according to the power setting.
Seems like your YN560 is defect and having problem with recycle time.
camera, dslr, flash, k7, photography, yn
K200d flash issue oatman911 Pentax DSLR Discussion 3 05-22-2010 03:36 PM
Built in flash issue goldenzebra Troubleshooting and Beginner Help 15 04-11-2010 07:24 PM
Flash exposure issue slawek Flashes, Lighting, and Studio 20 07-10-2009 09:38 PM
Flash issue liberiabound Flashes, Lighting, and Studio 9 11-09-2008 07:15 AM
Workaround for flash WB issue on DS. Lipo Digital Processing, Software, and Printing 1 01-02-2007 10:36 AM
All times are GMT -7. The time now is 07:17 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
