Originally posted by i_trax yes the foil works all the time but why do we have to do it?
I did e-mail Pentax AU couple of times asking for firmware upgrade and/or add to menu stop-down metering and auto-focus on/off.
there is very similar problem with using Pentax-F 1.7x AF teleconverter with old K and M42 lenses, when you attache to it old K lens with silver base ( large enough to short all contacts and conductive) - all fine.
when you attache the lens with black anodised mount - need to use foil.
when you attache M42 lens with Pentax M42/K adaptor - need to use foil.
maybe this group should put some global pressure on Pentax to implement those necessary changes ASAP!
kind regards
There may be a reason(s) they don't want the camera to function with no lens attached; personally I agree with you and I'd like to be able to control it.
However 'til they change things, you'll find that using foil tape works well.
