I encountered this crazy thing while working on another post of mine, but thought it'd be better to highlight it in a separate post.
https://www.pentaxforums.com/forums/showthread.php?p=1269779 Also, because this is not something that you'd notice easily as we don't do a microfocus adjustment often. Here goes:
Here a horror that I discovered about the K7 (at least mine) while I was really trying hard to get something else going with a lens BF FF problem. My K7 is running v1.10. I noticed that no matter how much microfocus adjustment I applied, it did not seem to matter, as if the cam had decided beforehand what to do. For some reason today, I swiched OFF and back ON everytime that I changed the microfocus adj. And OMG, the change is now reflected even if there is a 1 notch change!!!!
Here's what I did:
1. No microfocus adjustment change is registered by K7 when you get to the menu and change it, hit the "OK" button and immediately start shooting (I have a habit of half-pressing the shutter-focus button to spring the K7 system back into action for shooting). That is, without getting back using the "Menu" button. But, after hitting "OK", the damn thing confirms with a "SAVED" on the display. I believed it all these days!! What a waste of time!
2. microfocus adj. change is properly registered by K7 if you switch it OFF and back ON after the change. I don't know if it even does that if you "gracefully" come out of all the menu options to the status screen by hitting the "MENU" button repeatedly after it said "SAVED".
I swear, this is a real let down of all that precious night-time I spent without sleeping trying to test a lens. I really want to check if anybody else has noticed this. Is it a v1.10 bug, or is it just my cam. I strongly think it must be a bug.
Cheers,
Anil
