Originally posted by gibikote Hi
Apologies straight away for posting multiple queries/thoughts in one thread, but they are all related to my K100D (or me!).
These are well posed, important questions; I hope I can help a little.
Quote: Here are a few observations related to the images from the K100D (my only DSLR). I almost always shoot JPEG. I mainly do some casual photography of family, few birds on free weekends (they are rare arent they?) etc. Like to experiment with rain, night shots etc. but dont end up doing as much as I would like.
a) many are oversaturated (yellow) and need to be corrected. Especially ones I take in the outdoors. I do birds with a Tamron 500/f8 mirror handheld.
If you get ANY 500/8 handheld photos you are doing well indeed. I don't know why some (rather than all) are oversaturated, but that's not hard to fix.
Quote: b) are often blurred. No, I dont have a tremor
This is mainly indoors, with either the 16-45 or Sigma 70-300.
I have a feeling the SR is not really functioning.
Not ALL images are blurred; I do get good ones. Perhaps the focus is not right sometimes (I guess these can be easily differentiated).
It is most likely your technique; perhaps you are punching the shutter button causing motion blur. You can do some tests:
Put the camera on a table or tripod and take some time delayed or remote triggered photos in the troublesome exposure range, SR on & SR off. If they are ok, you are the problem, not the camera.
Look carefully at 100% crops of problematic images for motion smear (bright points of light extended into short lines.)
Shoot at a tilted target. Then you'll be sure something should be in focus. Then you can also check on focus repeatability, by you or by AF.
Practice SQUEEZING the shutter button - thumb below the camera, finger on the button, slowly close the thumb-finger distance - do not push the camera down with your finger.
Quote: I have yet to fully understand and get to terms with 'stop down metering' using the AE-lock button with the M lens. Suggestions on this would help too.
Practice and take some notes. Sometimes a particular exposure compensation is required for a particular lens. Use M mode (but Av mode may work with the K100D).
Quote: What should I be doing? (with tight budget in mind)
i) Get a new body - that will be more M lens friendly, better SR, better color rendition? An upgrade would be to a used body, not a new one.
I doubt that a new body will be more M friendly, have much better SR, or better color rendition. BUT a K-x or newer body would be much better at high ISO, therefore your low light success rate would be MUCH better.
Quote: ii) Get better lenses for indoor
Good new lenses never hurt & a faster lens will decrease low-light motion blur problems; but you should be sure your technique is good too.
Quote: iii) theres nothing wrong; keep trying with steady hands, as all bodies have plusses, minuses. All images will require some level correction sharpening etc.
iv) none of the above (you tell me)
Your experiments will tell you if you've technique problems, the ISO advantage of the K-x & newer cameras is real.
Dave
PS sometimes focus is off or there's motion blur in an important photo. I've found FocusMagic to be a useful tool in correcting such problems (yes, it can actually make a bad lens better, or bring an out of focus image into focus.) It is worth its small investment in my independent opinion.
