11-19-2010, 08:35 PM   #1
Is my K-7 body causing back focusing??? what shall I do?
Hi guys!
1 month ago, I found that my *16--50 back focuses at f/2.8 between 45--50mm on my k-7 body. I thought it was the problem of the lens, so I sent the lens to AZ for repair.
1 week ago, I bought a *50--135, which still back focuses throughout the focal range... Now I suspect the symptom may be caused by the body. So I found another k-7 body and put the *50135 lens on, the result is: the lens is still a little bit back-focusing, but much less severe than on my body.
OK, so based on these facts, can I say that my body causes all the focusing problems? Or it still might be a body-lens-joint-effect? I already have the replacement *50135 on the way, but I am not confident at all that it will perfectly match my k-7 body...
thanks a lot for all the inputs!
11-20-2010, 05:20 AM   #2
amoringello's Avatar
Look in the manual on how to fine adjust focus. (I cannot remember the menu item off hand)
You can make a global adjust, or fine tune each lens.
Better to try that on your own than do without camera and lens for several weeks.
You will want to get a focus test chart, (http://focustestchart.com/chart.html)
Follow directions closely and make sure the problem is actually a back/front focusing issue.
11-20-2010, 09:20 AM   #3
Wheatfield's Avatar
QuoteOriginally posted by amoringello Quote
You will want to get a focus test chart, (Nikon D70 Focus Chart)
+1, and read the rest of the manual while you are at it.
11-20-2010, 11:52 AM   #4
thanks guys!
I did try to use the in body focus adjustment, the only concern is that it is a zoom... and it only severely back focuses at the 50mm end, so if I adjust it to, let's say, +10, then it will cause the 135mm end to front-focus...
11-20-2010, 01:43 PM   #5
QuoteOriginally posted by shang Quote
Depending on what your focus distance and f-stop was when you tested at 50mm, almost 2/3 of your in-focus depth of field would be behind the point of focus. A common mis-conception is that it should be 50-50. At the long end you would expect the split to be almost 50-50, but still favoring a depth behind the actual focus point.
body, camera, dslr, k-7, k-7 body, lens, photography
Is my k20d back-focusing? wasim_altaf Pentax DSLR Discussion 3 04-05-2009 08:10 AM
K10d Back focusing FullertonImages Pentax DSLR Discussion 2 04-01-2009 03:23 PM
What Does Front and Back Focusing Mean? GregK8 Troubleshooting and Beginner Help 5 02-28-2009 11:47 AM
MZ-S back focusing celetron Pentax Film SLR Discussion 1 09-09-2008 03:24 PM
Manual lens focusing: what is causing this? kerey Pentax SLR Lens Discussion 10 11-17-2007 02:51 PM
All times are GMT -7. The time now is 01:13 PM. | See also: NikonForums.com, part of our network of photo forums!
